AC not blowing cold at idle
BatsTDK
Orange County, CA
I’ve noticed at stop lights and idle that my AC is barely cold. Once I get the engine going, it’s nice and cold.
I’ve read conflicting info that the condenser isn’t getting the airflow it needs so it’s not effective at idle. Or it needs a recharge. Or it’s overcharged.
Anyone else experience this?
GMT800 2005 Tahoe Z71
Navy Supporting Member
IMO, it does sound like it is undercharged. You may also have a problem with the a/c condenser. At speed the air flow is ok at the condenser and at idle the air flow is way down and does not dissipate the heat at the condenser as well. There was some years of condenser problems but would have to check for the effected years. Is the condenser on either the Yukon or Suburban the original one? Care to share which rig has the problem? Is it a secret?
Tonyv__
Bucks county PA
My 2000 Tahoe that I sold a few months ago had this same exact problem. Kid I sold it to took it straight to a mechanic and said it had a tiny leak and was low on Freon. They fixed it and charged it up and it apparently worked great after that
BatsTDK
BatsTDK
Orange County, CA
Oops I forgot I still had the Suburban on my sig... sold it a few weeks ago so gotta take that off. This is the Denali I’m referring to.
Here’s some more interesting info... I found a hose and gauge I had from one of those refill it yourself Freon cans and the gauge says it’s overcharged by about 30psi. Does that seem right? I thought if it was overcharged, it wouldn’t work at all.
It is going to depend how quick the fan clutch reacts to the lack of air across the condenser. I agree that the fan clutch/fans need to work correctly to help the a/c work at idle but his share of a reading is of no help. Need a set of gauges hooked up and post what the high and low side readings are at idle and is the clutch cycling.
TheAutumnWind
I've read clutch fans aren't that great in the cooling dept if you're sitting still. Electric fans cool great once they kick in while idling.
Clutch fans can potentially move more air than electric. The clutch may be ready to be replaced.
OP can you hear your fan at idle? It should be pulling enough air to for it to be plenty noticeable if its warm enough that you need to run A/c.
Otherwise get some gauges and check the pressure in your system.
ks03
Fool Excess Member
So you had the same mediocre cooling when idling with your clutch fan?
Yep, seemed like by the time I came to a stop at a red light the ac was hardly doing anything. Holding the revs just above idle helped, but a PITA. I didn’t want to travel with dogs in the summer before, leaving the ac on while parked and going inside for 10minutes didn’t seem acceptable, afterwards it can maintain.
The wife even thinks the blackbear tune was a reasonable use of $ ,since it allows the pcm control, couldn’t care less about anything else it did.
corvette744
2004 Z-71
Northern illinois
Same problem here i can care less about anyone in the tahoe i care about the dog when i run into store and leave it running.Im going to check that out more this summer its 40 degrees here so dont need it yet.If everything is right with pressures and i have a new clutch fan on it now.I will just install a cheap elevtric fan and turn it on when its running..I have one on my big block street car easy to install.The electric fans seem like a big hassle to install.
BatsTDK
BatsTDK
Orange County, CA
No it’s pretty quiet at idle. I think maybe temps haven’t warmed up here enough for it to kick in more?
TheAutumnWind
if the truck is up to operating temps and you are sitting idling for awhile and its warm enough to run a/c you should hear that thing sucking air imo.
If you think the clutch fan is good then get gauges and tell us the reading. They are like $50. If your pressures are good then aux fan is an easy project
ROGELIO A GUZMAN
Los Angeles CA
Fan clutch time. I had that issue. Replace the fan clutch. I put a severe duty fan clutch. Here in california we have alot of traffic. Helps keep truck cooler. And also a 160 thermostat. I also replaced a china radiator the last owner put in. Replaced with a ac delco and all over heating issues stopped.
Javie
Burbank Ca.
Yup i'm willing to bet it has something to do with the clutch belt. Fan spins slower at idle so less cooling.
Mooseman93
Start simple. Check the tensioner on the ac belt. I've had two now that lost tension. There was still enough that it worked decent at highway speeds but at idle it was hot. It's a $30 part and not super difficult, if that's the culprit.
Otherwise, yeah the fan clutch would be my next target.
Also, don't trust the "free" guages that come with the cans of refrigerant. They're ok in a pinch but not really what you need to do the job right. If it's low, a common spot for the leak is the low side schrader valve.
veteran111
