Being a two wheel drive without the CV axle it was actually super easy. Once I got the 3 bolts put the hub essentially just fell out lol MUCH easier than it ever was on my 07![]()
Oh well in THAT CASE!!!!
Oh well in THAT CASE!!!!![]()
I’m loving it. It’s handled the snow pretty decent tooWish mine was 2WD.![]()
Any issues braking the hub out of the knuckle? I had a **** of a time doing my last one.
Being a two wheel drive without the CV axle it was actually super easy. Once I got the 3 bolts out the hub essentially just fell out lol MUCH easier than it ever was on my 07![]()
That’s true too. Definitely a very low amount of corrosion to contend with at this point. But the lack of axle shaft sticking through the hole (giggity) also makes a difference. Sometimes that shaft holds on for dear life! LolI think the bigger difference is this vehicle has not been soaked in the wonderful elixir of salt and snow that exists in the north.
Interesting. Guess, I’ve never had an issue with the axle shaft hanging on.That’s true too. Definitely a very low amount of corrosion to contend with at this point. But the lack of axle shaft sticking through the hole (giggity) also makes a difference. Sometimes that shaft holds on for dear life! Lol
Years ago now I bought a defective hub. The thing literally lasted 2 weeks if that and was the last time I bought a cheap hub assembly. When I went to replace that 2 week old hub I had to beat that thing out as if it had been in there for 5 years cuz that cv axle wouldn’t let goInteresting. Guess, I’ve never had an issue with the axle shaft hanging on.
it was an awesome time had by all.That would suck. My guess is the cheap hub didn’t have hardened splines and it gauled up on your shaft.Years ago now I bought a defective hub. The thing literally lasted 2 weeks if that and was the last time I bought a cheap hub assembly. When I went to replace that 2 week old hub I had to beat that thing out as if it had been in there for 5 years cuz that cv axle wouldn’t let goit was an awesome time had by all.
Possibility. It’s been long enough I don’t remember all the intricate details. Just enough to be the old guy with stories to tell from his porch and straw hanging out his mouthThat would suck. My guess is the cheap hub didn’t have hardened splines and it gauled up on your shaft.
New key fob case cuz the one I carry all the time was literally breaking into pieces cuz old plastic is old
I don’t care about having an Escalade or 2015+ fobReally? Who doesn't seize this opportunity to get an Escalade or 2015+ fob? You're a whole different breed of savage.
I don’t care about having an Escalade or 2015+ fob![]()
to be honest, the only reason i care about having a fob that works is because it allows me to get into the car while it's raining without fumbling for my keys. In the end, if the keyless entry system just went into the toilet I wouldn't care about that either.
I didn't even know that was thing
Sway bars finally arriving this week so those will be going on this week. Spohn panhard bar is close behind, as well. Next up, will be going a little bit lower. Probably 2/3.any progress is good progress burb!
