juicedgsr95
I've got a 2019 LS with the standard stereo (no subwoofer) In the jack storage area there is an unused plug, is this for the factory sub? Can I pull an audio signal from this plug to add a sub? Anyone have the pin-out?
That fits under the center console?! I’m definitely looking for something to replace my crap sub in the Denali... do you have to add an amp or will it power from the factory amp ?Factory sub under center console on Bose system, I am replacing that with JL Audio stealthbox, after hearing it in the same truck as mine I was sold
https://www.jlaudio.com/collections...gm-4gsuvcnsl-10tw1-car-audio-stealthbox-94644
Need to add amp
Awesome! I had a JL 10W3v3 in a small sealed box, powered w/the A1400 mono amp, 500 watts RMS @2 ohms, in the trunk of my 97 Deville (RIP) and have been itching to get that bass performance back. The Yukon XL has a little more cabin volume than the trucks but I'm hoping performance is similar to what you're experiencing. It surely will be better than the stock amp w/cheap plastic enclosure.I am shocked how good the base is with the JL sub and no boxes to look at
Mine took about 3 weeks to get, their web site said 3-5 days, but we were told it would be 3-5 weeks when we ordered it. You can't believe how poor the stock one is until you replace it, really happy no boxes taking up room in my truck, and really good bassI'm getting the stealthbox installed at the end of January - scheduled for the 29th assuming they can get it in by then. I had heard there was a delay getting those since they are nearly all made-to-order in Florida but the installer didn't seem to think it would be an issue. I'll post my thoughts on the before/after. Hoping it'll be a big upgrade and still integrate well with the rest of the system. I'm also getting the RC-1 bass knob added so I can turn it up/down from the driver's seat. Amp is going to be mounted in the cargo area, under the load floor cover thing.
The stealthbox came in on time and the shop got most of the install done today. I could have picked it up basically as they were closing today but work was busy and I didn't want to rush them so I'm going to pick it up tomorrow
How do you like the stealthbox? I've been contemplating getting one for months, but I'm worried it would cause rattling issues in the center console or dash.
No rattles, I had a lot of sound deadening put in thru the truck and doors, made the music sound even better without as much road noise
Hey, I am definitely enjoying it thus far. Ended up picking it up last Saturday (Jan 30th). Still want to adjust some of the settings but I'm waiting to do that until they are done with a fix on the install. They used a line-output converter that also provides a 12v remote turn on to tell the JL amp to turn on...and if I don't have the volume at 40% or higher, the Kicker LOC doesn't output enough on the 12v lead to keep the JL amp awake...and thus it turns off after about 30 secondsThe install place was going to correct it this past Saturday but I already had plans so they are going to fix it this upcoming Saturday (Jan 13th).
Kicker makes the LOC and from what I can tell, the LOC itself doesn't require it's own power - it converts the high-level signal from the stock Bose sub amp into a 12v DC output for the remote turn on (in addition to the regular LOC function of RCA's for the JL amp inputs). Apparently it is harder to find a switched 12v wire in the newer vehicles and this Kicker LOC was supposed to solve that problem by eliminating the need for a relay.
Anyway, once that is all fixed/happy, then I'll play with the crossover frequency. They set it to 80hz and 24db cutoff slope...I'll probably keep the 24db slope but might lower the crossover. I also have a JL 10w3v3 in a sealed box from a prior vehicle that I want to test out just for kicks. I got the HD-RLC remote level control for the sub as well which I 100% recommend. I had it installed just past the lower dash trim, driver's side in front of my right knee. I can still lean forward and reach it but it's outta sight and they didn't have to drill any holes through the lower dash piece = win
To answer the question on rattles - I haven't heard any yet but haven't played around w/it too much still...haven't been driving much w/working from home + the snow in the philly area.
We're like neighbors, they do good work, never installed anything for me, but purchased many things thru the years from them. My installer who did my Tahoe sound system and radenso radar and laser, Joe Bruno Designs installed the dyamat, everything was removed from my truck inside, when I saw it I thought it would never go back together without rattles, but you hit a pothole or railroad tracks and less noise than stock which shocked me, thought I would be searching for rattles for years, but noneNice, that is good to hear. I forgot to mention that as part of the install they basically snip the wire that feeds the noise cancelation to disable it. This is different than the "Bose Autopilot", the noise canceling cannot be turned off via a setting, need to cut the wire. It can be "undone" and re-enabled if you ever put the factory sub back in. I wasn't sure if this was 100% necessary but after some Googling, an aftermarket sub (more powerful) creates a feedback loop where the noise canceling adjusts the signal to the sub in an attempt to cancel out some of the bass...which makes the sub sound different, which then makes the noise canceling change again, etc, etc, and apparently it sounds horrendous.
I am convinced I am hearing more road noise now lol - probably just my imagination since I know they disabled the noise canceling...either way, I was debating adding sound deadening to the doors + floor.
Did you DIY the sound deadening or pay an installer? The shop that did the install for me (World Wide Stereo in Montgomeryville PA) uses Dynamat brand exclusively so I'd have to use their stuff...I'm sure it works fine but I think I'm paying a premium for the "Dynamat" name. The increased product cost and paying for the labor is tempting me to try it myself. I have experience taking panels out, replacing speakers, etc...I just have a fear of putting it somewhere that causes clearance/panel fitment issues.
