kbuskill
NE. FL.
A simple powered plug like.. perhaps the cigarette lighter it replaced?
ya any GM usb port is going to be data and charge as far as I know, I have never seen a gm usb port that was charge only, you could very easily use the gm usb port and then connect the rear mini usb port to power only, the 12v to 5v usb power adapters are all over ebay and amazon it's very simple conversion I use one for my dashcam which is hardwired to accessory power via usb.
madmanjustice
i could never find a matching trim piece for a good price (cheap) so I found this one for $40 and with about 50 cents of vinyl (that almost matches) did this.
The vinyl wrap job is not perfect (my first try) but i have plenty of vinyl to do it again.
Last year when my mechanic had to remove the dash to replace to AC condenser they did not get the harnness for the DIC switch back in its location so I am going to have to go back to them and make them fix that (free of charge of course) so I can hook up the DIC switch
20210109_152858.jpg 20210109_152902.jpg 20210109_155545.jpg 20210109_155548.jpg 20210109_155804.jpg
YETI the Yukon
