2021 Leveling/Larger tires
GeauxTahoeGeaux
Georgia
I’m a new 2021 Z71 Tahoe owner and am changing the tires from the stock Goodyear Wranglers to something else. I have upgraded tires on other vehicles and have historically used BFG KO2. I love the BFG KO2s but since the vehicle is new I’m trying to decide what to put on and have some questions.
My Tahoe has the air suspension and I want the best of both worlds. I want the wheel well to look good and full and don’t want any rubbing. I’m considering slightly larger tires but don’t want to mess up a good thing. The vehicle will primarily be in Normal ride height and drop to the lowest ride hide when exiting/entering the vehicle. I don’t care what the Tahoe will look like if I raise it above Normal height because that will only occur when on my job sites and that’s extremely rare.
So, my questions:
1. Does anyone have BFG KO2 tires on the 2021 Tahoe?
2. Does anyone have Nitto Ridgegrappler or Terragrapplers on the 2021 Tahoe?
3. Has anyone with the air suspension put on larger then stock tires?
STORMIN08
in the past i was a huge fan of the BFG's...somewhere around the late 90's - early 2000's, the compound went to crap and they wore really fast...i switch to the TOYO brand of AT or MT tire (depending on vehicle)...AND HAVE NEVER LOOKED BACK.
the newer AT2 and AT3 are amazing tires, and regularly wear to 65K miles with no issues.
GeauxTahoeGeaux
Georgia
The more I've thought about it, I'm going to go with BFG KO2s in the stock size 275/60/20. I don't want to do anything to jeopardize ride quality, MPG, etc.
The dealer will install them next week. Will post pictures in case anyone is curious.
Artem-G
Vancouver, Canada
I’ve got BFG KO2s on 18” tires on my 2021 Yukon. The ride quality is way better, but the grip on flat asphalt pavement is very bad compared to stock tires.
With stock tires, spinning the wheels when starting in 2WD was very rare, and would almost never happen in AWD.
With KO2s, wheel spin is typical even in AWD mode. In 2WD, I tend to drift every time I accelerate when turning!
Oh well, I guess city/highway driving was never supposed to be KO2’s strength.
gat0r
DFW
FYI,
Auto (on upper left on selector) is 'Automatic Four-Wheel Drive'... not AWD
its for 4hi when conditions vary
Jsenky
please post the pics!
i replaced the stock tires with same size bfg ko2s on my ‘16 ltz 4wd tahoe at 26k when the stock crap tires wore out. I have put 50k on the ko2s and have no regrets.
Planning on doing the same once my stock wranglers wear out in my at4. Ive already had a stick go through my sidewall. These tires are garbage so hopefully they wear out sooner than 26k.
olyelr
Elk Rapids, MI
I dont understand why people have to “wear the tires out” before changing them out. If you dont like them, dont suffer through it for 25+k miles, sell them while they are new and put the money toward your new set.
STORMIN08
i regularly sell mine off with very good tread life left. i lean towards the Toyo AT...65K mile tire, only a set or two have i kept that long. i generally remove about half way to upsize or just to have a fresh look
GeauxTahoeGeaux
Georgia
Scheduled to have them installed tomorrow and front window tint. The weather is a little iffy but will get some photos up in the next couple of days.
GeauxTahoeGeaux
Georgia
I negotiated in the purchase pulling the stock tires off and installing the BFG KO2s. I can’t remember if it was $400 or $500 but they agreed to replace the tires with same size BFG KO2s and install Chevrolet floor liners and cargo liners. Thought it was a great deal.
GeauxTahoeGeaux
Georgia
Quick question, new tires, same size, are going on today. The service manager said with a new vehicle (only 300 miles on it), I won't need an alignment with the new tires. Does this sound right? I've always had alignment done with new tires but it's always been on older vehicles with more miles. I thought the alignment had more to do with the new tires then the age/mileage of the vehicle. Thoughts?
STORMIN08
alignment is of the hard pars...can a tire cause issues...yes. but generally the alignment highlights worn hard parts.
you have this performed when installing new tires so not to wear them prematurely
GeauxTahoeGeaux
Georgia
Tires put on today but tint won’t be done until later (tint guy left early).
Here’s some pictures of the 2021 Z71 Tahoe with new BFG KO2 tires (stock size 275/60/20). Truck has air suspension so I took different photos at the lowest setting and the Normal setting.
It was rainy so not the best photos but hopefully this helps folks get a look at what to expect. I love the way they look on the Normal Drive height and they ride great!
olyelr
Elk Rapids, MI
Heck yea man looks good!
how does it look in off road mode?
JR09country
Thanks!
I will take some more tomorrow and make sure I document what photos are taken at what height.
Nice. Id be curious how the ride is in offroad mode. Some one posted earlier in the thread a link to sensor adjuster where you can keep it that way in "normal" mode .
Sent from my ONEPLUS A6013 using Tapatalk
Bryingram4
San Diego CA
Looks great!! Do you or does anyone else know if it is possible to go any larger on the tire size while still keeping a 20” wheel??
DWSmoot
DWSmoot
Charleston, SC
I’m leveled and running a 11.6” x 33.6” diameter tire. 22” but wheel size doesn’t matter. Just focus on overall diameter. Also seen several folks running 33x12.50 with a level.
justinakay79
