Adjustable Panhard Bar Options
drdave81
Waterford, MI
I'm planning on a 2/4 drop this spring, starting to collect parts now. I know Spohn has an adjustable panhard bar, but saw that Rocket Man said there is hardly any clearance for the diff cover. He installed a QA1 bar, but I wasn't able to tell if it was adjustable or not. Their site doesn't even show one available. Are there any other companies or is Spohn about it? I haven't had any issues with their stuff on my old F body, just like knowing what my options are.
Crippin87
You should be fine with the spohn panhard bar. I lowered my rear with the TB springs and have the spohn bars on mine and haven’t had an issue.
Dantheman1540
Sugar Loaf Mountain
If you plan to keep the stock diff cover then the Spohn bar works good. If you want a bigger cover or a different axle like a 14bolt I suggest the QA1 bar however its not adjustable.
Staggered 02
Correct. If you are going to use the stock dif cover. You'll have no issues. I am lowered 1.5 / 4. No issues. Love the panhard bar.
Just realized, I don't have a good shot of the panhard bar. The spare tire needs to go too. just added that to the things to do list.
91RS
GA
What sway bar links are those? Are they shorter than stock? I'm trying to find some shorter ones that aren't the DJM offset ones.
Staggered 02
They are Hotchkis sway bar end links. They are shorter for the lowered applications
1BADI5
DMV
Hellwig makes an adjustable rear end links too; that's what I have.
That's right, I forgot the QA1 panhard bar was because of the TA girdle.
Yessir. If you want a girdle and still need an adjustable bar I heard Spohn will make you one with the bend like the QA1, they have a form to fill out for a custom one. Not sure what it costs.
I’m lowered 4” in the rear but my tires are centered side to ride within 1/4” so it wasn’t worth it to me to move things 1/8” over.
drdave81
drdave81
Waterford, MI
I never get updates for threads on here lol. I'm planning to go about 4" in the rear as well. For now I'll be sticking with the stock diff, so shouldn't be a concern. Good to know that they'll make one in case.
26AT4
