89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
@89Suburban
The OEM tight fitting Oil Filler Tube PN: 609729947
I don't see any listings for it unless you want used, but being it's a one time use...
Doing some searching you might be able to find some new old stock somewhere.
(grabbed it hoping it said "710" on it for lols with the wife, nope!)
:D
Thanks dawg.
89Suburban
SE PA
I pop the end off the coils then spin the plug end of the wire around a few times. Then slowly pull out on it as I work the end in a circular motion. Sometimes I have to grab the heat shield with some long needle-nosed pliers and wiggle and pull it by that.
Your so ******* sexy sometimes :)
Next part number question:
WHY DA EFF ARE THERE TWO DIFFERENT PART NUMBERS FOR THE REAR GLASS LIFT STRUTS?!!
My original ones are labeled 15161943 LH and 15161944 RH for the left and right sides, respectively. I can't figure out why there would even be two different ones, unless the piston or ends don't swivel like 99% of every other lift strut in existence.
Anyone ever used Strongarm #6157? What about Sachs or Stabilius? Those two have left and right part numbers as well.
Just Fishing
Can't fix stupid
Utah
I have this cap but not retainer. I have to place mine in pump all the time. Is that piece available separately?
I found just the retainer, but it's $$
buy the "used" for $10
that's what i did, it was a perfect fit and i used the cap it came with.
never really thought about the left/right thing, my passenger side started leaking so I just replaced it with a oem one
kbuskill
NE. FL.
I replaced the lift struts on my rear hatch with the Strongarm lift struts.
I am not a fan. If I still had the old lift struts I would put them back on and send these back.
Sometimes when I hit the button and the gate starts to lift it will get almost all the way up and then the lift motor acts like it encounters an object and it will stop and begin to close again almost like the struts are working against the lift motor.
It doesn't always do it but it has done it several times since replacing them.
There was nothing really wrong with the old struts. I replaced them as preventative maintenance thinking it would make it easier on the lift gate motor and gears... guess I was wrong.
I chose the Strongarm brand because they were supposed to be higher pressure (stronger) struts.
wjburken
Eastern Iowa
This is the second post on here recently of someone having issues with Strongarm gas springs. Interesting.
received one side, there was only 1 tracking number I assumed they had shipped them together, morons now to play the ***-n-tat amazon game and wait for them to ship the other side.
I have used the strong arm in the past they didn't make it 2 years and crapped out
Whale, shit. I ended up ordering them since they seemed to be more popular than the other brands. The GM ones were $35-$40 each. My hatch works fine and these are for the glass, so I'm hoping their smaller ones are ok.
Have you noticed if yours acts up only or mostly in cold weather?
didn't seem to make any difference hot or cold
kbuskill
NE. FL.
Colder weather definitely makes it worse in my case... which is what usually happens when they get old and worn out, which is what ticks me off because these are brand new.
wwiizz
