Lower dash switch options
Sparksalot
Bastrop County, Texas
I’m curious what the combinations of available switches were in our trucks. Both of my PPVs have the single traction control switch and a useless cubby. See first pic. I’ve seen a version that has 4 switches. Second pic. The exploded view shows 4 modules as options for the location. I’m curious about the others. Are they just versions with fewer of the same switches, or something else?
I’m curious because I want to see what I might suddenly gain with just a switch addition. Alternately, I might reuse one or more of those for something else.
NathanJax
Vacation Nathan
Jax, Fl
ones I know of....
-adjustable peddles
-traction control
-parking sensors
-heated windshield washer fluid was there, but they removed that, and had a recall to disconnect and remove the heater part
Sparksalot
Sparksalot
ones I know of....
-adjustable peddles
-traction control
-parking sensors
I know about that recall. It happened about a year after I had a Saturn Outlook mysteriously catch fire and burn to the ground.
After I got thecopcar, the reverse lights quit working. It turned out to be the reverse relay which is hardwired into the under hood fuse panel. The replacement part was fully populated with fuses and relays, except one. Tracing it down, it was the washer reservoir heater fuse.
kbuskill
NE. FL.
Here is mine...
It originally had the heated washer bottle which was deleted during the recall by the previous owner.
I repurposed it to operate my 42" light bar behind the grille...
Just FYI, the heated washer button is a momentary switch that works off the ground side so it requires a latching relay to turn something on and keep it on.
If you just wanted to use it for something like a train horn it would work without a latching relay.
Sparksalot
Sparksalot
Here is mine...
That’s the kind of idea I have.
how well does your light bar work behind the grill?
Just Fishing
Can't fix stupid
Utah
Ooo what's the pn for that?
I had to check mine to see how many buttons i have.
Just Fishing
Can't fix stupid
Utah
about 18 shipped, what the heck. :)
I compared the pin out between the 3 button i have and this one.
Seems to be the same plug, just this one has more pins.
Should be easy enough to add pins should they be missing...
also makes it easier to figure out what pins are for the extra buttons. :beer:
Sparksalot
Sparksalot
That was my thought. I haven’t gotten into it yet to see if the harness already has the pigtails in place.
EvergreenZ71
Firefighter EMT/First Responder
Washington
Interesting. I’ll be watching for updates on this too for clean looking mod controls.
rvsatx210
Here is mine...
I saw someone on youtube that had the light bar behind the grill as well but didn't really get into how they did it. Is there a post I can look at that shows steps for this because I would like to do this on my 2010 Suburban
87carl
Does anyone have a pin out or wiring diagram for these switches
kbuskill
NE. FL.
scottd
