Lower dash switch options
Just Fishing
Can't fix stupid
Utah
about 18 shipped, what the heck. :)
I compared the pin out between the 3 button i have and this one.
Seems to be the same plug, just this one has more pins.
Should be easy enough to add pins should they be missing...
also makes it easier to figure out what pins are for the extra buttons. :beer:
Sparksalot
Sparksalot
Bastrop County, Texas
That was my thought. I haven’t gotten into it yet to see if the harness already has the pigtails in place.
rvsatx210
Here is mine...
It originally had the heated washer bottle which was deleted during the recall by the previous owner.
I repurposed it to operate my 42" light bar behind the grille...
Just FYI, the heated washer button is a momentary switch that works off the ground side so it requires a latching relay to turn something on and keep it on.
If you just wanted to use it for something like a train horn it would work without a latching relay.
I saw someone on youtube that had the light bar behind the grill as well but didn't really get into how they did it. Is there a post I can look at that shows steps for this because I would like to do this on my 2010 Suburban
87carl
Does anyone have a pin out or wiring diagram for these switches
kbuskill
NE. FL.
skimask
