2007 denali prone to continuous problems? Should I keep mine?
Rosko
Hoping I can get some responses here from people that own this vehicle, and maybe have more miles so they can give me an idea of what to expect.
Background: I owned a 2004 Yukon XL, I was starting to have a lot of electronic issues among other things I was replacing. Though it was paid off, it was starting to cost me quite a bit in repairs with little driving. I decided to purchase a 2007 yukon xl denali to replace it, hoping the electrical issues and other things might be worked out, or better in this model. Now I'm not so sure.
Vehicle: 2007 yukon xl denali with 82k miles.
I took the vehicle overnight to check everything out, the funny thing is that everything worked multiple times, perfectly, not one issue electronically or mechanically. I tested every switch/function 3-4 times to make sure there weren't issues, took the vehicle back the next day and made the purchase. On my way home, and the next evening, here are the problems that cropped up.
Problems
1. Driver power folding mirror grinding/not working (worked great for 24hrs)
2. Cruise control doesn’t always work. When the cruise will not “set”, I can tap the brakes or lightly tap the brake pedal left/right and it will begin working typically. Guessing it needs a new Stop Lamp Switch, P/N 25981009.
3. Intermittently, the ambient light sensor or something else (BCM?) does not recognize that it’s daytime. Sometimes it works properly, sometimes not. With any moderate amount of light it should change the interior lights much brighter, the nav/screens/dash lights should all be bright, and daytime running lights should activate. Instead, it leaves the headlights on, interior lights are not visible enough (can’t even really tell what gear you are in with normal sunglight, and navigation is black instead of white).
4. I ran the vehicle through a car wash, passenger light has fairly bad leak/still has water inside.
I've only had the vehicle a few days, purchased it last thursday, but I'm seriously considering just asking the dealer to take it back. I've already talked to them, and I think they are going to try to fix one or two issues. I really like the vehicle itself, the way it drives, power, overall condition etc, but I really don't want a money pit again.
Anyone else here have the same vehicle/experiences, and considerations? Curious how many miles you have and how trouble free, or not, it has been for you.
I appreciate any time you take to post thoughts.
sickk23
New Mexico
I'm not sure about a lot of that other than hopefully it's a few simple quick fixes. But I do know that the Yukon's headlights are always on, they don't have a dedicated drl so whenever in gear, your headlights are on.
R
Rosko
How it's supposed to work:
It actually does dim, but yes you are correct no dedicated DRL, it uses the same bulb. When it senses daylight, it will turn the dash lights on much brighter so they are visible in sun light, as well as the nav will turn white instead of black background. The headlights also dim, but they are still on. When it senses less light via the ambient sensor, it turns the headlights on brighter and the dash lights become controllable via the interior light dimmer, navigation turns black BG.
krzyd
Sunny N. FL
How dark is your tint?
R
Rosko
Everything is factory. The windshield is not tinted which is where the ambient light sensor is located.
Another note: Just to test it out I've shined LED flashlights directly on the sensor when it's not working, and it still never turns the lights on, even with bright sunlight/flashlight on it etc. Then other days it works flawlessly...as expected.
R
Rosko
Hopefully after these little issues I won't have a lot more. I love the design/powertrain of the vehicles...just don't want to deal with the ongoing issues that sometimes crop up in GM electronics.
R
Rosko
Well I guess I'll probably keep it. Luckily the dealer is putting on a new power mirror today at no charge. They aren't able to reproduce the ambient light sensor problem though, sometimes it works, sometimes not. I ordered the stop lamp switch for $10 on amazon....hopefully will last some time now.
harveje
ambient sensor is 13-15 install is simple BUT be extra careful due to thin dash and trim. I just broke my trim piece where sensor is located...oooouch
Smokymance
Boosted
MI
Its a love/hate relationship, as will all cars...iv had most of those issues with mine since i have owned it...but what you gona do? all those gadgets, some are prone to go bad!
R
Rosko
I agree. I've got 4 kids so my car buying choices are pretty narrow anyway. What else has the room/features/torque other than these babies? There's just not much else out there for the same price.
Smokymance
Boosted
MI
Unless u want a conversion van!
Provide the proper maintenance, it will be fine...
Read thru the forums and keep an eye out for easy stuff to maintain, the rear tail gate for example. There is another thread here stating many people with the power lift gate always going bad, most of the time its just the struts that cause issues....
GM Customer Service
Michigan
Rosko,
Hey there! I am sorry to learn that you are experiencing an issue with your vehicle and your local dealership is involved. I would be happy to look into this concern. Please private message me if I can be of any assistance.
Jennifer T.
GM Customer Care
BRUTUS_T_HOG
Sell it while you can or be prepared to spend some money up front. I have put oil pumps in 4-5 2007's in the past year. There is a TSB for the oil pump relief valve sticking and causing no oil pressure.
The one I just did last week just dropped a lifter and has a dead cylinder. Huge job to replace the lifters they decided to trade it in.
R
Rosko
Brutus, where do you work? Is it a common/guaranteed problem they all have? How many miles were on them, or does it seem to matter? Any way I can preemptively just replace a simple part and not worry about it?
I can't imagine with all of the Denalis/Yukons on the road that they'd all have this same problem without a recall.
BRUTUS_T_HOG
There would only be a recall if it is a safety concern. I have seen this problem on engines with 50k-150k. Doesn't seem to matter on miles, or maintenance history. The one I did last week was sparkling clean inside yet had no oil pressure.
I work at an independant shop.
R
Rosko
So the only way to tell if you are losing pressure is to watch your guage/lights on the dash...and be quick to shut the engine off?
Does it always cause damage or do you have a few seconds to catch it/prevent it?
Dh1280
