Jason in DLH
Cheeseburger and Fries
Not my thing, but it’s cool if you like it.
Sheesh...tough crowd. First my family. Now my internet people.
Doesn’t matter what us goofballs think. If you like it, then that’s all that matters. You do you!Sheesh...tough crowd. First my family. Now my internet people.![]()
So I finally made it out and took a picture of how my parking brake cable is routed after leaving the firewall. Is this the norm for anyone with this year/body style?
(2011 Yukon Denali 6.2l)
per my father-in-law i drive like i'm on a race track.
I just tell him i like to feel the G's
And i drive my vette like i stole it most of the time.
my tires don't last long...![]()
I Just got the low down on these high volume pumps. If anyone else is curious:
https://help.summitracing.com/app/answers/detail/a_id/4825/~/do-i-need-a-high-volume-or-high-pressure-oil-pump?
*Bump*
Does anyone have their Parking Brake cable routed through the two holes in the frame, or do they all run next to it?
I went with OE this time. I had been noticing what I thought was a stumble while at idle. A week or so ago the driver side mount went and I started getting the clunking on takeoff. The new OE mounts made a huge difference. All the vibrations are gone.Hummer mounts? You DIYing it, or taking it somewhere? I need new mounts, but the videos for AWD make it look pretty daunting.
Lol, why didn’t I think of pulling the engine? Would have made getting to the block bolts so much easier!I'm doing all of mine too, but something tells me that replacing mine will be easier than doing yours...
I just had the wheel well liners out of my 2012 Suburban while changing motor mounts. My cable is ran the same as yours. I think routing through those holes might cause binding.So I finally made it out and took a picture of how my parking brake cable is routed after leaving the firewall. Is this the norm for anyone with this year/body style?
*Bump*
Years ago when I built the motor that's in my 5.0 mustang I used a high volume oil pump. I have a Vortech supercharger that has engine oil plumbed to it for lubrication, and also use a 7qt baffled pan (2qts more than OE). The baffled pan keeps the oil near the pickup during spirited driving (hard launches, cornering, heavy braking). Oil pressure has been fine.Melling has some great information as well. That article by Summit isn’t really helpful for guys trying to correct an oil situation in a worn engine. Here’s a quick explanation on pressure vs flow that puts it in an easy to understand comparison. Melling has some videos and other articles that can help a person to decide on an oil pump. https://www.melling.com/wp-content/uploads/2017/03/pressure-vs-flow.pdf
However, I don’t have a loose oxygen sensor sitting in there like yours, lol.
Working underneath any vehicle sucks unless you have a lift. It’s amazing how awkward it is to lay on your back and work overhead.Last night I removed the gas tank, charcoal canister and vent valve. Today I'm blowing out all the lines back and forth and I hope to have it finished by tonight. This job sucks on a lowered vehicle!
I’m sure it’s much easier. Never had that luxury. On my back for life!Working underneath any vehicle sucks unless you have a lift. It’s amazing how awkward it is to lay on your back and work overhead.
