Service Safety Restraint System error
James Mill
They have replaced the clock spring wire in my steering wheel and believe that was the issue. Picking it up this evening and I will post updates to let the group know how it goes.
kidtriton
“Some customers may comment on a Service Safety Restraints Sytem message displayed in the DIC. When checking for DTCs, a B14DC symptom 1B and or 13 will be set in the K36 Resyraints Contol Module. This DTC is for an open or high resistance in the F106DA Driver’s front seat in order airbag deployment loop”
Hope this helps.
Hope their fix actually sticks.
Good luck!
This makes sense because when mine was doing it a lot it seemed like it was when I moved around in the seat that would trigger it. What's weird is we are seeing reports of the steering wheel area with clocksprings and bag connectors as well and I find it unlikely there are this many different factors but time will tell.
James Mill
Driving home and then to work today, no warning message. My Bluetooth phone connection continues to act up, though. Time will tell.
AZ71TAHOE
Arizona
2021 z71 purchased on 09/12. Service Safety Restraint System showed up on 09/13 and continued intermittently thereafter. Took to dealership on Monday and was told "not safe to drive until fixed" and that "tape is on backorder for at least a month". So glad I spent $$$$ for this Tahoe to only end up driving a Trax loaner...should've just bought 3 of those instead...
olyelr
Elk Rapids, MI
Or 1 and a half Rams.
Margaret Rowley
kidtriton
And this is one reason I won't take mine in yet.
Hondogreif
Just got vehicle back from repair. They said the code for my problem was “Steering wheel air bag at stage 1 has high resistance”. They replaced steering wheel airbag and air bag module. Hopefully that will take care of it. Will definitely give update if it comes back.
1 week later and all is well. Fingers crossed it will stay that way
AZ71TAHOE
Arizona
Update: Got a call today, tape is now in and Tahoe should be ready tomorrow. Fingers crossed GM has seen enough of these to have finally figured out a fix for them and I won't be going back in with the same problem in a few weeks.
Bigmanny
Bigmanny
Tape did not work for
Me. Told that they are replacing the airbag module and connector in the driver seat. I should have the car back tomorrow.
Giangi
Hello All, I have a 2021 Tahoe Z71 with 2684 miles on it and I started to have the warning message today! I joined the club !
2021 Tahoe Z71 5.3L 4WD Graywood Metallic
PATMAN3737
Purchased the 19th Started when I drove off the lot, In for service the 2nd time on 3rd day. Tape worked for 30 miles, now they say turned over to TAC. In my testing it's been the steering wheel. I am short so was thinking maybe because I extend the wheel all the way out and up. I was able to slow it down for a while my moving the wheel in and down some, but today was like day one and nothing helped.
Giangi
Is it safe to drive the vehicle in this condition if I don’t have time for a stop ?
PATMAN3737
No it is not, If the airbag light is on they are not working according to the service department.
Did the dealer fix it? Concerned that something this new and they will not know what to do.
Wait...you’re worried the dealer won’t know what to do because it’s so new but we will? Hahahaha. Nice one. I feel so smart now. Thanks!
PATMAN3737
Just got it back yesterday, been 70 miles since, so far so good, will update after more time has passed. At least GM has a TAC case open on it now.
James Mill
UPDATE: after replacing Clock spring in steering wheel, no issues for a couple of hundred miles. Fingers crossed.
venom260
NE Indiana
2021 GMC Yukon Denali
Purchased: 7/30/2020
1st SRS/Airbag service performed: 8/27/2020 with 865 miles
"Inspect & Cycle Driver's front seat inboard airbag connector, apply butyl tape and retest. Performed service bulletin, test drove, & didn't act up"
2nd SRS/Airbag service performed 9/4/2020 with 1007 miles
"Repaired the right side air bag in the front driver's seat, performed bulletin to repair."
Called dealership on 9/17/2020 to report SRS/Airbag warning light flashing again. Dealership said GM guidance on this issue is to now replace airbag and connector. New airbag arrived at dealership on 9/22/2020, but the connector had not arrived.
Called dealership today on 9/28/2020, connector still has not arrived. Expecting it to show up on 9/30/2020.
Looking forward to getting this issue resolved. Keep ya'll posted.
BadDaddy2003
