89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
I see no videos for the cables, anybody ever had to deal with these?
wjburken
Eastern Iowa
**** me!!!!!!!!!!!! :(:(:( Thanks.
Same on my 2013.
08z71bgm
Long Island, NY
I also put a brand new battery in yesterday. All day today the voltage gauge is under 14. While yesterday it was above 14. Does this have to do with the amp sensor not turning on the alternator?
89Suburban
SE PA
Sam Harris
Can you guys see this bump stop pounding away on my brake cables? Causing another potential repair because I see the one cable sheath looks to be busted open and some rust on it? :mad::mad::mad:
Does anybody have pics of that area on your truck and how it looks like they should be routed??? Something is not right there.
View attachment 257483 View attachment 257484 View attachment 257485
No shit! Seems like those zip ties are holding it in the wrong location!
PG01
Up here to the right
Yes
if you want, hit tow haul button while idling and watch gauge. It creep right up to the middle and hang there.
Yesterday it was probably charging and today it doesn’t need much. It will go up when needed.
89Suburban
SE PA
Yes
That’s interesting!
Pretty sure you can disconnect them halfway up the middle of truck and reroute them under axle then reconnect.... they are at least 2 pieces
This. I disconnected mine to route above the sway bar (but still below the axle) when I lowered it to give some slack on the shock body. You gotta put a little ass into it to pull 'em to disconnect, but they'll unhook fairly easily if they're not corroded. You're gonna have to replace that/them cables since water has already gotten in and is rusting the cable inside.
Disconnect the RVC sensor on the negative battery cable and see if the voltage goes up and stays up.
*EDIT*
I'm slow to the party. I missed the last page.
Drewphil
