I have a 2007 Tahoe Z71 4x4 with 185k miles. Its rough around the edges but everything works. Ive put 20k miles on it in the last year so it is still reliable and runs fine
my question is, I am debating on putting 3-4k into it to get some of these items fixed or do I just let it keep leaking/slowly breaking down. Or, do I sell it and get something else. I imagine some of you have crossed this bridge at one time or another and curious if you regretted investing the money or vice versa.
current issues:
-oil pan leak
-rear main cover leak (i think)
-front diff leaks out of both axles
-exhaust manifold small leak (both sides)
-Rack and Pinion Leak and worn mounting bushing
-driver seat front tilt doesnt work (might not fix)
Additional Items I would like to have done:
-install magnaflow 18” muffler
-Install transmission cooler (going to tow boat and toys)
-maybe install new driver seat with heat and cooling not sure the cost
-replace ujoints as I think they are still factory.
Parts I have already replaced:
-rotors all around
-both front wheel hubs
-both front cv axles
-both tie rod ends
-driver motor mount
-master cylinder
-valve cover gasket passenger
-valve cover (new design) driver side
-passenger brake caliper
-windshield
-belts
-plugs
-both front upper control arms
-front struts
-rear shocks
-headunit with apple carplay
-fresh ac recharge
-battery
current issues:
-oil pan leak
-rotors all around
-both tie rod ends
-driver motor mount
-master cylinder
-windshield
-belts
-plugs
-front struts
-rear shocks
-fresh ac recharge
-battery
