Headliner Restoration
Matthew Jeschke
Sahuarita, Arizona
Couple questions. First this is continuation of old post. I don't know why, my old posts are no longer idexable from the site. I have to search them in google:
https://www.tahoeyukonforum.com/threads/refinish-headliner.111963/
Question 1: I'd eventually like install a gun rack and or molly system on the roof towards back. Pretty sure it would attach through the coat hook mounting points. So I'd like to find a different clip system than the stupid coat hooks. I got replacement coat hooks for the back but is there something better? That I can actually take off again. These coat hooks are a nightmare design.
Question 2: one of the former owners of the truck took the headliner out once before. They really beat it up around the pillars. I want to rebuild those corners. Does anybody have a video on how to do that? Perhaps with fiberglass patches? Not sure...
robnarley
North GA
Junk yards are your friends. Buying a used one will be well worth it versus the time, energy, and money spent trying to repair. Recovering it yourself might be worth it if the used one has the fabric sagging. I paid $100 to have mine recovered, but I did the removal and reinstallation.
FWIW, I just keep the last email notification from my threads in my inbox so I can quickly return to them when I want to. I don’t like relying on search functions.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
I recovered the sunroof shade. Was getting ready to do the headliner... then my wiring harness bit the dust :( I have dash completely disassembled trying to find the problem. Hopefully I can find it soon so I can finish the headliner.
Sent from my SM-A505U using Tapatalk
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
I am on the mend from my misadventure taking my dash apart. I need to figure out something with the headliner. More specifically the rear coat hooks that hold up the headliner. I got new coat hooks. However, I'd prefer not to use them. I'd like to do something (1) that is easier to take apart and (2) allows me to do a custom mount.
Are there any good alternatives to those crappy coat hanger hooks that hold the headliner up?
https://drive.google.com/file/d/1V0-v7MlUw06WwKT0EM25evc_kCrIwJou/view?usp=sharing
wjburken
Eastern Iowa
Would something like a nutsert work? You could attach a piece of steel with a nutsert centered on the opening for the coat hook to the back side of the bracket and then make a replacement clip that you can put over the headliner when it’s installed and bolt the clip to the nutsert. A couple sheet metal screws should be sufficient to hold the piece with the nutsert in place while you install the headliner.
They make a manual rivnut gun too that’s like a big pop rivet gun that’s not too expensive.
REXBETI 14" Rivet Nut Tool, Professional Rivet Setter Kit with 7 Metric & SAE Mandrels and 60pcs Rivnuts, Labor-Saving Design, Extra 1/4-20 mandrel with Rugged Carrying Case https://www.amazon.com/dp/B07MVXN7LK/ref=cm_sw_r_cp_tai_sBzfFbX063JE5
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
that is an awesome idea... only thing, the nut is smaller than the hole for the clip :/ I'd have to seld that hole shut or something.
wjburken
Eastern Iowa
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
I'm getting there! Stripped old fabric off the headliner this evening. Couple questions:
1. It almost doesn't look clean, feels clean but doesn't look clean. There are dark streaks and lines all over the place. I tried to use a scotch bright to get it even cleaner. Is there a chemical wash I can use before putting the new fabric on?
2. I have some damaged corners. I had brought this up before, but is there a way repair some of these beat up corners?
https://drive.google.com/file/d/1ESecncxnlZf8xUltzKzvNe0hgfY7X3e9/view?usp=sharing
1. It almost doesn't look clean, feels clean but doesn't look clean. Is there a chemical wash I can use before putting the new fabric on?
View attachment 255295 View attachment 255296 View attachment 255298
Dirty is fine, as long as it's smooth and clean of old glue and foam. I've never had to fix one, but I've heard of guys using fiberglass mesh to fix broken pieces.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
I was thinking of going to walmart and getting fiberglass supplies like that.
I should elaborate, when I run my hand across the headliner there is a film / fjzzy feeling. However nothing really comes off with either the metal brush or scotch bright.
Maybe it's the fibers from the board itself--from rubbing it with the steel stiff brush. Just be generous with the headliner glue. Spray both the board and headliner material--let them tack up 1st then press them together--don't get any wrinkles or you're screwed, you won't be able to peel it back to reapply. I like to use a plastic bondo applicator to smooth it out as I'm laying the fabric down.
wjburken
Eastern Iowa
A few things come to mind. For the busted corners, could you get some foam board the same thickness as the headliner core and cut little pieces to fill in where the core is broke or missing?
As for the fuzz, I have seen where folks will out a layer of very thin material like kraft paper over the entire headliner and glue that up and then put your finish material on.
Here is an article I found that talks about it.
http://theamcforum.com/forum/repairing-molded-fiberglass-headliners_topic50000.html
Buford bubba
