89Suburban
Bull in the china shop
SE PA
Got this delivered by USPS today. Who knew, on a Sunday!
Won't be able to install it this week though, gotta wait till next week.
i NEED TO DO THIS.
Sam Harris
Yes, my truck is tuned and Thank You!
I still have my 102mm TB to install, but I know I will get a lean code.......so I'm going to install it right before it goes back on the dyno on Wednesday
Been thinking about a big TB and intake combo.. what about the air intake tube? You know of one that’s a 102mm..?
5strmtrp
The seal that slips over the metal lip around the entire perimeter of the opening? You have part numbers? I need to replace my driver's side. The oil spill from last weekend deteriorated the foam rubber.
Here you go:
Passenger side RIGHT. 22766410
Drivers Side LEFT. 22766409.
These are the ones that go over the metal pinch weld around the doors.
DO NOT USE GM PARTS DIRECT. Horrible service never get a response, all they do is open trouble tickets and leave you hanging by your nuts. I’m still waiting for 2 items from them that I ordered June 20th.
08z71bgm
Long Island, NY
Well I finally got the brackets. QC is a bit to be desired. They should really make sure the water jet cuts the holes 100% before packaging. Maybe clean it up a bit too. I know maybe I’m being too critical for 75 bucks. Lol also no washers for the bolts.
edit: so it’s also going to need to be deburred. The edge is quite sharp. I’ll most likely hit with a file and add rivnuts in the holes. Then paint the whole thing.
maxandpj
