George B
¯\_(ツ)_/¯
Care to share the write-up?
Hopefully this link to another site is ok.
https://gmtnation.com/forums/threads/setting-up-vcx-mdi-tech2win.19133/
If not I will copy and past it.
the vxdiag comes with techII win and gds II software, it's a little tricky to get the software installed and working but once you have it setup it works fine just like a techII, I have both and a mdi
yes, in any case you still have to pay the $40 for 2yrs of calibrations (per vin number) from TDS, generally it does the programming while actively connected to the internet, I haven't tried to download a calibration to install later I don't know if that is even possible, might be.Does this mean that it comes with the diagnostic and programming software. All I would need is a subscription to download the programs from the ACDelco site?
I think you (or I )might be confusedI believe it is only a pass through for the programming. I just want to make sure all the downloads needed are included. Other than the actual program file for the module. That I understand requires the fee and subscription.
the software for the vxdiag will be a on disc in the box and will require updates that it will download online.
calibrations and files that may be required for modules on the vehicle will only be on the tds website and is all done via the vin number
yes it will do that plus all the regular diagnosis that a standard tech2 would do (offline), there was supposedly something tech2 win can't do that a tech2 would but it must be something obscure because I couldn't find the details anywhere.I think we are actually on the same page.
If I understand correctly the software on the disc for the xvdiag includes tech2win which will allow troubleshooting and testing but calibrations and files that may be required for modules on the vehicle will only be on the tds website.
Thanks for asking. I should’ve written them down but didn’t. It was a generic error of some kind that the programming process couldn’t be completed. But then the headlights would blink off and back on and the thing would reconnect automatically and try again until it completed. Maybe it was normal?I have only programmed 3 modules, 2 HVAC controls and one BCM. I bricked the first HVAC module and was using Win7 (which is unsupported) against advice of GM’s Tech Line. I upgraded the laptop to Win10 and haven’t had any other issues. To be fair, I didn’t know what I was doing the first time and had support on the phone when I bricked that module. What errors are you encountering?
I don’t think it’s normal. Next time take a pic with your phone. I’m curious if it was during the download process. If it was during the actual flash process I’m pretty sure it would brick it. If it was during the download then it’s most likely your internet speed or their server. Are you using Wi-Fi and if so, make sure your signal is strong. I also plug the laptop and Tech2 into AC power, don’t trust the power in your OBD port to power the Tech2 because it’s possible that during the flash process that might momentarily lose power and that causes the Tech2 to restart.Thanks for asking. I should’ve written them down but didn’t. It was a generic error of some kind that the programming process couldn’t be completed. But then the headlights would blink off and back on and the thing would reconnect automatically and try again until it completed. Maybe it was normal?
Dave
Chiming in here with a word of caution on the programming side and looking for ideas. I have a Tech 2 that's new to me, but I've gotten it set up and working with a Dell Latitude Windows 10 laptop for the pass-thru capability from the acdelcotds website subscription tied to my VIN.
I'm a former Windows software developer, so I'm pretty comfortable with tech in general, but I'm having mixed results with getting the programming process to complete reliably. I'm running the Tech 2 with Candi module and the laptop all with their AC power adapters, but it takes 2-3 attempts for each module I try to program for the process to complete without erroring out. I haven't bricked anything yet but the potential is there. Anyone experience this and have a reliable solution?
Cheers,
Dave
I never even thought of trying it that way. Sure would be less cables in the vehicle.It's absolutely crucial that the car battery be fully charged when programming. The error codes on my last attempt alluded to this. Tech support said to leave the battery tender on while programming next time. I have not done pass-thru programming with a laptop yet. I download the VIN and stuff to Tech-2, disconnect, go to my PC, connect Tech-2 to PC and download file and then go back out to the truck. Has worked fine several times so far save for that one.
Next time you go to use the tech2 take the candi module out and disconnect the cable and adapter and be sure everything is clean (blow it out like a n64 cartridge) and re-seat everything and make it tight and use a different Ethernet cable, also while programming just set it down and let it do it's thing don't be handling it and moving it around, I haven't had any errors like that but I have had some connection problems and it was a broken clip on a cable so it wasn't staying inserted properly. Like others said power the tech2 from a 12vdc source connected to ac power and if you can have the battery on a charger also, most of the programming is only 10 minutes but even that is enough to cause a problem if the battery is not 100%. I was never a developer but I am certified technician I spend most of my time troubleshooting and doing what I noted above will eliminate possible problems.Chiming in here with a word of caution on the programming side and looking for ideas. I have a Tech 2 that's new to me, but I've gotten it set up and working with a Dell Latitude Windows 10 laptop for the pass-thru capability from the acdelcotds website subscription tied to my VIN.
Cheers,
Dave
Excellent advice, thank you. I was powering both the Tech 2 and the laptop from their respective 120v power supplies, plugged into the garage wall outlets, so no issue there. I did not have a tender on the battery though, but it's a good, 3 month old AGM battery. All the same, I will put a smart charger on it next time I try. I'll also clean and re-seat the cables firmly as you suggest. On the ethernet cable, I do have some good Cat6 ones. Will standard Cat5e or Cat6 ethernet cables work in place of the cheesy flat gray one that comes with the unit?Next time you go to use the tech2 take the candi module out and disconnect the cable and adapter and be sure everything is clean (blow it out like a n64 cartridge) and re-seat everything and make it tight and use a different Ethernet cable, also while programming just set it down and let it do it's thing don't be handling it and moving it around, I haven't had any errors like that but I have had some connection problems and it was a broken clip on a cable so it wasn't staying inserted properly. Like others said power the tech2 from a 12vdc source connected to ac power and if you can have the battery on a charger also, most of the programming is only 10 minutes but even that is enough to cause a problem if the battery is not 100%. I was never a developer but I am certified technician I spend most of my time troubleshooting and doing what I noted above will eliminate possible problems.
*also be sure you have the ac/radio and things like that turned off, some programming may require the drivers door to be shut or the parking brake set just depends usually it will prompt you as needed.
Good catch. My '12 Denali has its factory HU, but my '07 does not, which is what I'll be working on this weekend. Excellent timing on this advice, thanks!Also I found out from tech support- if you have an aftermarket stereo head unit, remove the fuse so it can’t power on period. The Tech2 starts off by waking up all the modules in the vehicle and does a handshake with them so it can read it’s programming. If it’s aftermarket it can get hung up trying to communicate with the stereo. If you notice when you look at DTC’s in a vehicle with an aftermarket HU it will have a code for no communication with the radio.
Interesting - I'd like to try that. Does the Tech 2 power down when you carry it between the truck and the computer? Maybe it doesn't matter?It's absolutely crucial that the car battery be fully charged when programming. The error codes on my last attempt alluded to this. Tech support said to leave the battery tender on while programming next time. I have not done pass-thru programming with a laptop yet. I download the VIN and stuff to Tech-2, disconnect, go to my PC, connect Tech-2 to PC and download file and then go back out to the truck. Has worked fine several times so far save for that one.
