Chert_Detective
IMO, that's one of the points of declads- cool but cheap! I planned to paint mine black, but scored a deal on some 22s. Have plans for some center caps?
Just going to get some 3.25" Ebay specials and paint them in the same color.
I'm still in about $200/ea, I did the painting and chrome removal myself but took them to a repair shop after I got all the foam off to have them acid dipped, sand blasted, and lips machined to get rid of all the damage (last picture, bare metal before primer). But yeah, try finding a great looking 6 spoke wheel in a decent offset that's under $200. I don't like my factory Denali wheels and I'm certainly not daily driving on $1,500 worth of Mickey Thompsons haha so this was just a cool project to get some decent looking wheels to throw some regular street tires on.
Sam Harris
RESlagle
Cleaned it
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
I washed mine in the car wash and was very disappointed by the outcome. The rinse water was dirty and left terrible spots. It ended up causing it to rain today so after I took the wife on a short shopping trip in the rain I wiped it down in the garage. Much better. I really want to wax it but it is going to the body shop in a couple weeks and needs a bunch of touchup. I picked up a can of engine cleaner and washed it down under the hood. Much better!
BG1988
I have not ran the engine for a 4 days is it normal to make like a valve slap noise? it only did it for a few seconds or is it a sign that the engine is going out :(
well i did not have it on for several days 4-5 days so i'm sure all the oil drained out it has not done it since
My guess is a dry lifter. Mine sits for a week or two most times and I had a lifter that would tick at that first startup. For the past year, I've been holding the throttle pedal to the floor and cranking the engine for about 20 seconds (two 10-second sessions with a minute rest in between) to build a little oil pressure before starting. This significantly reduced the severity and length of time it would tick. I'm currently replacing all of the lifters and a bunch of other stuff.
If it always does this after sitting for a few days, either start the engine every day or every other day or prime it before cranking.
Isn't that the infamous piston slap people talk about?
Piston slap would happen all the time after a cold start and not just after it has sat for four days.
BG1988
it only did it that one time since I bought it
the last 20 starts were not an issue ( 6 key turn starts 14 auto stops)
2 cold starts
the cold start PSI it pretty high about 60PSI even though it was 90F I expect it to be less as it's prewarmed up from being warm outside
it did not misfire when it happened
Escalade2007
