George B
¯\_(ツ)_/¯
An hour one way. Maybe he will ship for you.
Pretty sure I read the Nelson harness melts. The wiring can't take the load. I think @Rocket Man mentioned it before.Damn. I want that! [emoji16] you local to them?
I like my alternator 60kw of power 4,195 amps @ 14.3vI know that on my old Esky I had the 160A alternator rebuilt into a 200A and it didn't like to charge at idle.
I was going to have my buddy rewind it to 260A but he said the bigger you go the less it will charge at idle.
The solution for me was to swap to a smaller pulley on the alternator which alleviated the idle charge problem.
I had also converted the mechanical fan over to dual electric fans on that truck which caused more current draw, obviously.
I like different opinions, why would you not overdrive the alt?
I have been toying with the idea of OVERdriving the alternator because when my K5L fans run on hi, my voltage gauge is around 12V. I can't imagine what UNDERdrivig would do to the charging system.
Did you remove the starter to access the flex plate to torque the bolt...?
Is that Powerbond 25% underdrive balancer smaller or larger than stock?I'm running a slightly smaller pulley on the alternator..........charging system is still running properly
Very cool. But I’m wondering why you wouldn’t just program the BCM (ECM?) to activate the fans based on temp?
Ok. Thanks man.An hour one way. Maybe he will ship for you.
Good to know. Nvm..!Pretty sure I read the Nelson harness melts. The wiring can't take the load. I think @Rocket Man mentioned it before.
But it might be worth getting it just for the fans.Good to know. Nvm..!
battery's keep saying low even though I disconnected the rvc so I have one on desulfation on the charger, if this doesn't work then I guess it's time for new battery's, say's it takes 24 hours and then it will automatically switch to charging mode.
Nice.Changed the oil in the Yukon as well as the plug wires.
Actually, my 16 year old son changed the oil and swapped out the plug wires.
