James Ward
2015 Tahoe LT
I'm at the point that I need to change the oil and filter. What is the difference from a AC PF63 and a PF63E ? And is that the right oil filter, or is there a better choice ? Thank you !
I'm going to throw this out here for what its worth...
I am a member over on "Bob is the oil guy" and the talk of the town over there currently is the "Fram Ultra".
I have never used Fram do to my prior research BUT after reading up on the Fram Ultra I am thinking of switching my dual remote mount filter setup on the Burb over to them on the next OCI and see how they perform in the next UOA.
I ran that one a few times with no problems. Really, I can't say I've ever had a problem with any oil filter. IIRC, the K&N was a little cheaper (at Walmart) and an equally as good or better filter so I went with that.
I wouldn't use anything with the word 'FRAM' on it, near it, once referred to as such, nor do I ever in this life even think of anything, even if it was for my pets and beneficial to same. FRAM is the last thing I'd ever consider for my Truck.
And this feelings are dur to their OWN actions. They pissed down too many legs, (Mine included) over the years. When I worked in Garages for the years and years, they had a chance to improve their product, but money is what guided them, I'd leave a dirty oil filter on instead of using one of theirs. Now I hope they will never get $0.10 from me ever again. Since the 70's they have killed at least 50 engine I know of or have had interment relations of. Never ever !
Don't Buy E series filters they are garbage the filter medium degrades and if it happens to fail your engine will require replacement. it turns into a heavy duty Paper sludgeI'm at the point that I need to change the oil and filter. What is the difference from a AC PF63 and a PF63E ? And is that the right oil filter, or is there a better choice ? Thank you !
Prior research I had done showed me that Purolator Pure 1, Wix, M1, and K&N were all basically equal.
The guys on "BITOG" tell me that the Ultra does a better job of filtering smaller microns than the M1 extended performance filters I currently run.
The ultra uses a synthetic media vs the paper in the M1.
The K&N is extremely hard to argue with, due to the nut on the bottom, when the filter is in the factory location. On my remote mount it really isn't an issue to get your hands on the filters though.
Most guys, on here, aren't running 13k-15k mile OCIs like me, so for most they aren't getting anywhere near what they potentially could out of their filters. I guess what I'm saying is the filter probably isn't as crucial with a 3k-5k mile OCI.
I use no wrench to put it on, just my hands.....
I agree with those four filter recommendations.
I do 5K OCIs which is almost a year between changes for me. So, a dual filter setup probably wouldn't be very cost-effective. Or, would it? I mean, extra clean oil is good whether it's in for 3K or 15K miles.
You mind posting a link to what you have, or maybe where it is in your thread?
I installed a Derale 15749 dual filter setup...
Derale 15749 Engine Oil Filter Relocation Kit https://www.amazon.com/dp/B004XONTYI/ref=cm_sw_r_other_apa_i_X5ZfEbMV87TPA
Here is a link to my build thread with some pics of the mounting locations...
https://www.tahoeyukonforum.com/thr...urb-ltz-mod-thread.100141/page-3#post-1199569
I also installed an aftermarket oil cooler since my truck didn't have one already.
Then I ended up having hydraulic hoses made up for it so I could get away from those barbed fittings that came in the kit...
https://www.tahoeyukonforum.com/thr...rb-ltz-mod-thread.100141/page-51#post-1324392
