Was doing some prep work under the truck today and noticed that after ten years, the truck has never had a wheel alignment; or at least caster and camber adjustments. The plastic inserts on the alignment cams that were installed at the factory are still there after all this time.
Sam Harris
WOW!
my 03 Silverado was like that too drove straight and never had any weird tire wear
LRD_V8R
Got the lifter of death
Replaced all gaskets (except rear main)
Lapped valves
new valve springs
new timing set
AFM delete
new oil pump
replaced transmission cooler lines
new manifolds and studs (both rear manifold bolts broken on each head)
replaced significant amount of wire sleeves as most had deteriorated
replaced both motor mounts
ARP head bolts
ARP crank bolt
New water pump
Finally bought mats. I've still got the plastic from the dealer on the floor (purchased in April). :D
IMG_20191109_101828[1].jpg IMG_20191122_194507[1].jpg IMG_20191128_135610[1].jpg
R3cord303
Posse In Effect
Oregon Valley
Lapped valves
new valve springs
new timing set
AFM delete
new oil pump
ARP head bolts
ARP crank bolt
New water pump
View attachment 236360 View attachment 236361 View attachment 236362
Nice! What cam did you use?
kbuskill
NE. FL.
Lapped valves
new valve springs
new timing set
AFM delete
new oil pump
ARP head bolts
ARP crank bolt
New water pump
Wow... busy day... lol
Lapped valves
new valve springs
new timing set
AFM delete
new oil pump
ARP head bolts
ARP crank bolt
New water pump
Did it all without pulling the motor?
Where did you get the wire sleeves from?
The whole thing for 85? Is that normal?
No shit! Cheap!
Yes, complete Esky cluster shipped for $85. They go for over twice that normally. This place only had one picture of theirs ( not the pic I posted) and it looked like it was messed up so I asked the seller if it was just the way the light hit it, explained it was for a custom truck and needed to be close to perfect, and they said it was the picture and it was in excellent shape. They wanted $110 so I offered $60 and we ended at $85. Here's their pic. I have it in writing that it's in excellent condition so EBay's money-back guarantee will protect me if it's not but it's from a 2012 so I believe them.
BuckWild62
