Geoffsfas10
St. Louis
They are hateful engineers....thats all I have to say about that. All that work ( took 2 and half hours ) to remove both headlights, put in my switchbacks, resistors and LED headlights that were supposed to fit, only to have them hit the radiator support when put back...damn it. I know I can massage the supports but I will wait til I get a retrofit done before I start to cut and bash. But i couldnt settle with how the lights were forced back into place and they seemed to have some floating glare that I didnt like and i ended up removing them last night.
there is a easier way, I assume you took the bumper cover off? you don't have to
Geoffsfas10
St. Louis
No i left the bumper cover on which made it WAY more difficult...if the cover was off the headlights would just slide straight out. Im just going to leave it all alone for a while now
DaRosa218
The Dude abides
Modesto, California
That sucks, takes me about 10 mins to change out the headlights in my 2007 Yukon.
mikeyss
Longmont, Colorado.
My bun warmers and coolers stopped working. I already had replaced the connector and pins at the seat module last spring. So I was like WTF!! I
Did some digging and found a new burnt connector and a BARE ******* wire!! Also found the pins are sloppy in the connector. What clown at GM designed the electrical system for these GMT900's?! At least it didn't catch fire or totally destroy this connector, but think I'm going to make my own plug for the high voltage lines.
View attachment 235850 View attachment 235851 View attachment 235852
I would just bypass that connector period like you said, weak point in the system
Brian12019
