This weekends work...
PPV12HOE
PPV12HOE
NC
Passenger side complete...
PPV12HOE
PPV12HOE
NC
Also did my led treatment to all the exterior bulbs today... headlight removal is a pita... over all not a bad day... difference in halogen to led is night and day...
5strmtrp
Put my DIC in today... notched the trim and hot glue it into place... think it turned out all right...
Hmm, so you dremeled out the hole and hot glued it in place. Been looking around to find the trim but all I’ve seen is the wood grain. This just might work! Need to replace the center stack trim as mine is full of holes. Your job looks great
Ilikemtb999
Denver
I did the same thing. Start small and work it out. I used a hot razor blade to get it as clean as possible.
PPV12HOE
PPV12HOE
NC
Yup... taped it off, cut it out a lil small, filled it to fit, filed it out some more so the buttons wouldn't stick, then glued it in....
1BADI5
DMV
PPV12HOE
PPV12HOE
NC
Did you change the flasher or install resistors to prevent the hyper flash?
I've done the brake light and reverse bulbs, but nothing that flashes yet
I didn't replace the flasher or put in resistors... it does hyperflash... it did not with just the rears done but after I installed the fronts it did... it doesn't bother me enough to take them back out but I am gonna try a new flasher and hope it corrects it... thats what I did in my last truck...
1BADI5
DMV
Cool beans, let me know if the flasher does the job.
I'd like to do LEDs in the turn signals........... I like LEDs LOL
kbuskill
NE. FL.
Unfortunately, the GMT900 trucks DO NOT have a replaceable flasher... it is controlled by the BCM... you have to get it reprogrammed to be compatible with LEDs... basically you disable the "bulb out" warning indicator.
This place can do it...
2007-2014 C/K Truck/SUV Custom BCM Programming – White Automotive & Media Services
https://www.whiteautoandmedia.com/product/2007-2014-c-k-truck-suv-custom-bcm-programming/
PPV12HOE
PPV12HOE
NC
Thanks for the heads up... guess I'll just deal with the hyperflash for a lil while...
HeavyHoe03
