I remember a saying they taught us in electronics school to help remember, and it was totally inappropriate lmao. Here goes:
bad boys **** our young girls but violet gives willingly. I doubt they still use it. (Gold and silver are left out since they’re just tolerance limits).
Good ol Violet.Lol, i don't think im gonna forget that
Not sure if a OE 6.2 cat would work on a 5.3 or 6.0, but they’re definitely available from a scrappy and worthy of some punishment.
There's no point. Newer ECUs aren't fooled by resistors. They actually look for the readings from the downstream O2 sensors to follow the upstream ones in some predefined way. Resistors read as malfunctioning cats. Even when ECUs were "dumber", the simulators weren't 100% reliable. I occasionally had CELs on my '98 Cobra with simulators installed. I'd clear the code, and it would last a few months. So I lived with it, lol.I dont think anyone makes those O2 simulators anymore
Removing the cats will make the exhaust louder, so if you now have it to where you like it you may not after removal
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
That's why I had BB tune mine out. I won't be able to tell directly when the cats go bad. But when they do, I have the option to cut them out without the ECU caring.
This is absolutely wrong. The o2 sensor works the same as any other one. It gets a signal voltage, alters it, and sends it back. The return voltage is interpreted by the module. A resistor simply "adds" to the change made by the sensor. The return signal will still fluctuate the same, just at a different range.
If the module is not fooled, it's simply the wrong resistor. Theres no magic to it, it's not a data signal. It's just voltage, which you can control.
I will edit this a bit to avoid confusion:
1. I'm not talking about a spoofer, I'm talking about ADDING a certain resistance to the existing sensor.
2. The case where this does not work is one where the return voltage from the sensor is already too low, as opposed to not low enough.
You know what the saying is...Busy day today. Drained the coolant, did the flush rodeo, removed the driver side rear coolant plug with a 17mm Allen socket, replaced it with a block heater kit, refilled system with Dexcool & distilled water, replaced extremely noisy idler and tensioner pulley’s. Recrafted a bracket strap for my oil catch can (still catches a lot of oil even though I disabled AFM with HP Tuners).
Note that to removed the threaded freeze plug needed to use an impact-grade 1/2” universal joint with about 10” of extension to my 36” breaker bar. I was too lazy to grab the IR impact. Installing it was a breeze.
Have you reversed the upper shock mount bolts? If you turn them around so the heads are to the outside (tire) side, sometimes it helps since the bolt doesn’t stick out toward the tire. At least it does on the NBS.I just ordered four 1/4” Bora spacers. They’re supposed to be quality made in USA shit. Hubcentric and fine machine quality. Fingers crossed the studs are long enough to not need extensions
