Ahem....
What Is the Cause of Code P0430?
  • Faulty oxygen sensor
  • Faulty air-fuel sensor
  • Worn or internally failing catalytic converter (Most Common)
  • A leak in the exhaust system
  • Misfire (the root cause of converter failure)
  • Rich or Lean air-fuel ratio (the root cause of converter failure)
  • Leaded Gasoline (the root cause of converter failure)
. Excessive high speed driving
R3cord303
Posse In Effect
Oregon Valley
Ahem....
Pretty sure when i had my cat delete done it threw P0420 for drivers bank and P0430 for passenger bank.
Wolfbraid
Winston Salem, NC
In a previous car of mine, folks made MIL eliminators for the cats, basically a resistor pack that would alter the signal from the o2 sensor. Does anyone do that on yuks and hoes?
I guess in Cali you'd probably get arrested for that... ;)
I think the smog place just wouldn't pass you if they saw it, the chances of a cop looking for it otherwise are slim to none unless you had some absurdly loud exhaust system and got pulled over for it, the cops that look for modified vehicles only show up at car shows and things like that.
R3cord303
Posse In Effect
Oregon Valley
Tuner disabled those codes in the tune file
R3cord303
Posse In Effect
Oregon Valley
I heard they impound cars but not sure if thats true or not
depends, they do impound some but I think you kinda have to piss them off first, I read about on the police blotter every once in a while, they post daily stuff on facebook here, post up video or pictures of suspects, get people to snitch etc.
HiHoeSilver
Away!
Chicago
I did it on my 2000 z71 back in the day. Cost about $0.45 from radio shack if you know what you're doing.
Mickey_7106
Bay Area
I dont think anyone makes those O2 simulators anymore
HiHoeSilver
Away!
Chicago
Sure they do. Lol
wjburken
Eastern Iowa
This is exactly why I never pursued electronics, I was supposed to learn all those color codes and I was like naw F'it, lol wish I had now
When I was in college, my degree was Aerospace Engineering and we had to take one Electrical Engineering class. The problem was it was at 7:30 Tuesday and Thursday morning and I was either hung over from drinking while watching Monday Night Football at the bars or hungover from Wednesday night being Mug night. Needless to say, I didn't get an A and I didn't really retain much.
Since then I have kicked myself for being young and stupid as I have had to relearn/learn a lot of that for my various projects & jobs.
wjburken
Eastern Iowa
I learned them and quickly forgot them. We have Google now, no need to remember them.
I had a very wise instructor tell me that its not important to remember all the facts, just remember where you can find them. He said you forget and confuse things in your head which can lead to trouble.
petethepug
Michael
SoCal
On our work trucks in the 90’s we’d have to gut the cats in the field to get the truck home. There was no way we were going to allow a tow company access to all our HVAC equip and tools from our line of sight overnight.
The motor ran like shit and of course were loud. It upset the flow characteristics of the OE exhaust. Fast forward to the 2000’s here in Cali, I discovered that adding a cat from a larger displacement, higher performance model on one of our VW that’s supercharged woke up the motor along with it’s 1/2” increase in exhaust diam in the entire system.
It has better flow, removed a known drone @ 2800 rpm, much deeper sound without any cheap aftermarket buzz. Best of all it passes the CA Air Resource Board (CARB) visual smog test because it’s part number is VW, looks correct and bolts on. Can’t comment on any increase in performance gain as there’s no before/after dyno numbers but there’s definitely better milage and no more flat spot just before 5500rpm.
Not sure if a OE 6.2 cat would work on a 5.3 or 6.0, but they’re definitely available from a scrappy and worthy of some punishment.
I remember a saying they taught us in electronics school to help remember, and it was totally inappropriate lmao. Here goes:
bad boys **** our young girls but violet gives willingly. I doubt they still use it. (Gold and silver are left out since they’re just tolerance limits).
veteran111
