Obd2 dongle for torque app
kbuskill
NE. FL.
there is a test that the torque pro runs to determine the capabilities of the adapter being used, I bought a couple of adapters neither would even complete the test
I'm not sure... if you can tell me which menus to go into I can test it for you.
ok, I will try to get a screen shot in a day or two it's raining cats & dogs outside and probably for the next couple days straight and i'm already soaked I was out scrubbing caked up mud off the wheel wells since it was wet out already makes the job easier.
kbuskill
NE. FL.
I was looking through different settings and found a benchmark test that shows how many times per second it samples the PIDs.
This unit is benchmarking at around 23 with a max of 24.5. Not as good as some but for less than $15 I'm happy.
Also this unit is able to read and clear ECM, TCM, ABS, and SRS codes via the ChevroSys Free app.
Ihaveatahoetoo
