First world problems lol. You have a ‘19 so I don’t wanna hear any more whining.I do like the interior leds, def brightens the interior drastically..although on my 19 its like they put the smallest light possible....annoyingly small
yes the abs sensor, the abs system, traction control, stabiltrac all take a reading from each wheelHow does the tech2 test a wheel hub? Is it just the ABS sensor in the hub?
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
What was the part numbers you used and what year/engine? My driver side front diff mount is shot.
91 or 93 octane. less gear seaching then 87
on steep grades. it will stay in top gear longer
if you have a flex fuel use or mix your own custom blend. like e30
Yup, I filled up yesterday for the first time. Saved a bit @ $1.99/ gal, but also not impressed. Meh. I’ll stick with my beloved dino..
Hahaha, I installed some in my 00 Tahoe and now my fiance has forbade me to do the swap in the Escalade. I'll admit that I can barely see after using them for a couple of seconds.I did this too, but alas, my wife was not fond of the Color Temp... I haven't yet, but I'll be shopping a slightly warmer colored LED
actually be careful e85 makes it acidity if you don't have the correct compatible oil for E85 you can run into issues do keep it in mind..I use 93 exclusively. He drives easier than I do and it's still under 70° here so I cut him some slack. No steep grades around here. It is a FlexFuel, but I'd have to go far out of my way to get anything other than E10. After a past convo with @swathdiver, I did locate an E85 station in Baton Rouge that I plan to fill up from on our next road trip.
you have to use synthetic motor oil
Not sure about all that, but I only run full synthetic Mobil 1 anyway.actually be careful e85 makes it acidity if you don't have the correct compatible oil for E85 you can run into issues do keep it in mind..
Do the finance companies still keep the titles? The ones I've used the last couple years don't anymore. I have my title to the Denaligot the title finally, it was like waiting for a birthday card from gramma!
Cold Start
Speed engineering long tubes, stock muffler and resonator with no cats
Before 1/2" strut spacers....
31.25" front fender lip to ground
32.75" rear fender lip to ground
After 1/2" strut spacers...
32.25" front fender lip to ground
Looks great Ken, especially after. Who knew such a minor change could make it look so much nicer? Those are nice wheels not seen often too!
As for me and my house, the front brakes and driver's side hub are done!
This ^^ and.. 10 seconds.? What a tease!Sounds good but we need more...
We need to hear warmed up and revving.
it has always been my experience that you do not get the title until the loan is paid off, although in the past I have seen some other peoples titles with the lean holder on them beforeDo the finance companies still keep the titles? The ones I've used the last couple years don't anymore. I have my title to the Denali
2001 Yukon SLT
