Audio, side view cameras, 2nd Battery, Big 3
Chrismnj
Chrismnj
NJ
Doing this in my work van, not the Hoe. Gonna place the compressor for it under my hood. I'm more of a hands on kind of guy. How do you fuse #30 to the power source? Thx for the help.
Thinking of adding air horn to mine, I already have the compressor.
I have used existing Jcase fuse just made some wires for it, but you can buy a mini fuse holder or mini fuse tap bottom space is for existing fuse and top for your new device
I always remove the crimp connectors and substitute with heat shrink solder sleeve butt splice wire connector
Chrismnj
Chrismnj
NJ
Just open the instructions for switch wiring, Must be a Chinese translation.
Chrismnj
Chrismnj
NJ
Switches are wired in, forgot to mention if relay is used It would need power to the switch and if the switch has a light ground wire will be required as well.
Chrismnj
Chrismnj
NJ
I think I will change to blue rocker switches, not sure what I was thinking with that green.
Chrismnj
Chrismnj
NJ
ok I got another set of the gauges, because of the 4's were not wright on the first, there is some other difference in it too, look at the pic. who would like to have the 1st set?
Chrismnj
Chrismnj
NJ
Me me me
Sent from my SM-G960U1 using Tapatalk
ok, lets wait another week or so just to make sure they dont't ask me to send it back, if not they are yours, just asking you to cover shipping, or you local?
Chrismnj
Chrismnj
NJ
Same thing with rear hitch cover one of the supports is broken (not all the way) but I paid enough to request a new one, it wasn't a lucky delivery day both items came on the same truck. so if I don't get a request to send it back it will be up for grabs. This one is missing all mounting push connectors.
kbuskill
NE. FL.
View attachment 217429 View attachment 217430
I call dibs... lol
Chrismnj
Chrismnj
NJ
I call dibs... lol
ok same thing lets wait another week or so to make sure they don't request it back and its yours, please cover shipping cost. it is in black.
I all ready got new one
kbuskill
NE. FL.
Chrismnj
Chrismnj
NJ
If this works out I guess I will have to buy some more White Diamond tricoat... I've already used up the last of it I had when I color matched the bowties... lol
good glue and some push plugs for mounting it.
Chrismnj
Chrismnj
NJ
its just my luck, I had my daughters chest delivered and it was scratched on the top requested new one and they told me to keep the damaged one too. But the best one was with a subwoofer $1800 it was dropped and one corner damaged weight of this thing is like 200 lbs.
They tell you to keep the sub too?
veteran111
