2/3 to 3/4
Lwile
Plymouth ma
Hay guys I am in the process of lowering my 09 Tahoe again buy adding Belltech Drop Spindles 2511
To Belltech struts and pulling the spacer out of the rear so I am going from 2/3 to 3/4 at what point will I need to do trailing arms like DJM or Spohn I already have Spohn track bar and DJM sway bar end links and free travel mod Thanks pic is how it sits now
Looks slick with the black stocks!
4" rear is kinda iffy when it comes to needing the adjustable arms. What really matters is if the driveshaft still has enough slack in it when the suspension is bottomed out to not bind and be shoved up into the trans tailhousing. I think what usually drives people to get the arms is to push the axle back to center it in the wheel well because it moves forward the lower you go.
If it were me, I'd lower the jack with the rear coils out and shocks disconnected until the axle is bottomed out on the frame, then see if the driveshaft has any longitudinal play. The other reason for the adjustable arms is to set the pinion angle with such a drop. I think the stock geometry is pretty good at keeping the pinion angle within tolerances, but it doesn't hurt to be sure. Magnetic angle gauges are cheap and plenty useful elsewhere, so they're a good investment.
NeverSatisfied
eBay Baller
Wichita, Kansas
At 4” you’ll be fine with the stock setup. Adding the new arms at that height would be like stated above just to re center the wheels forward and back in the wells. They are a good investment regardless
Lwile
Lwile
Plymouth ma
Cool thanks for the info i will look into it when I do the back.and will the DJM trailing arm brackets work with the belltech shock extenders or can I modify the to work ?
Lwile
Lwile
Plymouth ma
Sorry for all the questions but regarding the front struts instead of using Belltechs spaces and a spring compressor can I just use 1 inch or 1.5 lift blocks under bottom of struts might be easier to adjust if I decide to go lower thanks
You mean not use the rings with the struts so you get their full 2" drop (4" total), but use the spacers to lift it back up 1"-1.5" so you net 2.5"-3" of drop? Sure.
Actually, I like this idea. I have yet to install my BT struts but lately I've been trying to determine if I want a full 4" front drop (with drop spindles) or if I want 3" or maybe go right in the middle at 3.5". I don't wanna have to take it all back apart just to add or remove a ring or two. Using your idea, it wouldn't be such an issue if 4" is too low. I already have 2" lift spacers that I could slice in half. Hmmm. I could also make each block a different height to level it left-to-right.
kbuskill
NE. FL.
Yes the DJM trailing arm brackets work with the Belltech shock extenders. I have both on the rear of my 4/6 Burb.
Byoung1330
Cookeville tn
This is my 04 with a crown 3/4 drop with beltech nitro drop shocks riding on 24s. It dont ride to great so was going to put beltech spindles on the front with factory keys back in. The back do the djm trailing arm relocation kit with sway bar links help the ride in the back. I've already done the free travel mod.
They look good on my phone but show up weird on the thread how do I make them better
Taking the pic from the same ZIP code would be a start. And don't use IG filters like you're trying to hide the guys in the club photobombing it from the sides.
Maw7989
Gillette, WY
Not trying to hijack, but I'm looking at doing a 2/3 drop on my 09 yukon and was wondering if you guys have noticed a drop in mileage?
Lowering the suspension won't drop the mileage at all. The odometer will read the same after the drop and mileage will only go up as you drive it.
Assuming you mean fuel mileage, I noticed about a 1MPG drop in mileage when I lifted mine 2" front/1" rear. I'd attribute this to the increased drag from more exposed frontal area of the tires, the increased area under the body and the more level stance that allowed more air underneath the body. I'd imagine a drop could slightly increase the fuel mileage, cause no change at all, or decrease it an almost immeasurably small amount from the change in aerodynamics (rear more level with front). I'd lean more towards an improvement, if anything, though.
justinesky
my cars get a little better mileage when i lower them due to drag
JasonW4141
