x2 on the oil filter or adapter, but you could pull that little inspection plate off and stick a mirror and flashlight up in there and check the rear main, oil of course flows down so bottom dead center is where you would see it flowing.
I'm looking for ones these clips, it is on the injector rail, if anyone has done a engine swap or just has one lying around, it is specific to the nnbs the others are different
93blkongreenpro
It’s horsepower sweat
This 5.3 couldnt bust a nut if Sunshine from Harlem Nights took a ride, lol
Its coming from the top of the oil filter so hopefully it's the block off plate. The oil change was done a few months ago and I parked it Sunday, so it's a new leak. It didnt leak all weekend at my sisters house.
Sent from my SM-N950U using Tapatalk
Ilikemtb999
Denver
Swapped a door lock actuator motor. Those buggers aren’t fun. Next time I’ll just weld the plate to the rivet before doing anything.
Ilikemtb999
Denver
Are they just hard to get to?
Removal is easy. You have to cut the head off of 2 rivets to get the actuator apart to get to the motor. To reassemble you’re supposed to then drill and tap said rivets to accept a screw to hold it back together. The rivets are probably about an inch long that hold the entire assembly together.
:think: Wheres the proof, i call shenanigans :D
Making before and after vids with a GoPro Hero3+ Black I've had for 4-5 years and JUST unboxed it for the first time yesterday. lol
I got it all updated, set up, etc. and now have a "before" vid on my PC. Gonna make an "after" vid then gotta figure out how to upload and post 'em. I'm a little slow with computers.
Laurents10
