USB charger replacement for cigarette lighter oulet
Ron C
Los Alamos, NM
Hello,
Is there a electrical outlet that has/is a built in USB charger, that I can replace a electrical outlet (cigarette lighter) with?
Yeah I know, I can put a USB adapter in there, but 1) the 'lid' won't close and 2) they get misplaced, and I don't want to listen to the whining etc.
I saw something like this https://www.ebay.com/itm/OEM-20944422-20983937-USB-Auxiliary-Plug-Retainer-Ring-for-Chevy-GMC-Cadillac/131445661911?epid=2292422996&hash=item1e9ac5a0d7:g:qRsAAOSwWKdbF6G1
But don't know if the connector in the back works with it. If someone knows about one of these, let me know the part #?
thanks,
Ron
With those, you'd take a USB cord with a micro USB cord and plug it into the back of your 2010+ radio/nav unit and the back of that adapter. I do not remember if it was male or female into the radio.
I did it and then removed them. Only one plug and on long trips my wife also needed to recharge her phone or whatever. Mine also were wired different since the radio was pre-USB.
Ron C
Ron C
Los Alamos, NM
That port is in use, by an SSD with all my music on it. (the port is not a hub, so it can only do 1 device).. Also, I don't like cables lying/flapping around.
Maybe I just need some BYOUC stickers....
Ron
ya if you look around on ebay there are some made that just plug in and replace the standard cigarette adapter ones, I personally just added 2 usb ports to the rear of the center console for the kids and still retained the regular plug, then added 2 more in the 3rd row on the passenger side
a quick search yielded this one, but I think there is one with 2 ports also, may have to just look harder
https://www.ebay.com/itm/OEM-209444...676438&hash=item56718ee465:g:r6EAAOSwxupbF57P
Ron
No, what I'm talking about, everything is behind the dash, nothing external.
Ron C
Ron C
Los Alamos, NM
Hi Wes,
I saw that one, but it looked like it needs to be wired with a micro USB cable?
How did you wire to power to it? (I only want to use it for charging)
thanks,
Ron
Hi Wes,
thanks,
Ron
you just remove the existing cigarette power plug and plug in the usb replacement, its that simple, the plug on the back is factory, no wiring needs to be done.
Ron C
Ron C
Los Alamos, NM
That is what I was wondering, if the existing connector from the harness would work with it.
Also, I looked for the "plug" with the two USB ports, but didn't see any of those. (do you know of a part number for that?)
Ron
Ron C
Ron C
Los Alamos, NM
This is what the cigarette lighter connector looks like, in my Tahoe
Ron
I just did a more broader search I guess there isn't a oem one with 2 usb ports, maybe I just saw the aftermarket ones that do have 2 ports
you could optionally add one of these, you would just need to tap into the wires behind the plug and maybe have to modify the hole if it does not fit exact, luckily it's just plastic so a small file usually works great.
https://www.ebay.com/itm/12V-24-Dua...f5:m:mRfRjsCeHgyMhGkllf6B0bg&var=572395677220
Ron C
Ron C
Los Alamos, NM
what year? the one I found on ebay is for 2010-2014, so if your is older you may have to change the harness connector as well, that wouldn't be difficult at all, it's just finding one is the tricky part
mine is a 2013 Tahoe SSV
Ron
Ron C
Ron C
Los Alamos, NM
https://www.ebay.com/itm/12V-24-Dual-USB-2Port-Car-Cigarette-Lighter-Socket-Plug-LED-Voltmeter-Waterproof/273129785077?hash=item3f97cdc6f5:m:mRfRjsCeHgyMhGkllf6B0bg&var=572395677220
I saw those too, but I'd rather go OEM. Besides, it's for "passengers" only anyway, since I put a wireless phone charger under the center console tray 'lid'
I'll try that OEM one and see how that goes.
thanks!,
Ron
that's weird I haven't ever looked at the connector for mine on the dash, the one in the rear of the center console and the one all the way in the very back match the one online, maybe there is a different part number to change the front? at any rate worst case scenario is solder in a couple wires and connectors and your good to go
Ron C
Ron C
Los Alamos, NM
Here is a pic of that USB port, showing the connector. I don't think it is just a charger,
Ron
PS: If anything it might just be like a USB cable, one type connector on one end and other connector on the other.
ya I was just looking at those again and was going to say it looks like it just has a mini usb plug on the back
Ron C
Ron C
Los Alamos, NM
I think I can make that work, I am going to try it with this thing I found on eBay: https://www.ebay.com/itm/2007-2013-Silverado-Escalade-Dual-Power-Receptacle-Cigarette-Lighter-USB-Bezel/381724395568?hash=item58e08c0830:g:K~IAAOSwyLlXog09
I'll just get a car charger, like I did for the wireless charger, and stick that behind it, without having to splice the harness,
Ron
schafer98
