Coolant in Oil - What Now?
Larryjb
Nope. Intake gaskets have no coolant flowing through them. Only, sometime, a coolant hose going to the throttle body.
Justinj360
Justinj360
Senior Member
Son of a *****... Excuse me I have a neck to go wring...
Larryjb
I'll have the dealer do that if they will.
This is really easy to do. You could probably have the valve covers off, tested, and back together before you'd drive it to the dealer, wait, drink coffee, wait, pay, then drive home. A coolant pressure test kit is likely cheaper than your visit to the dealer. Because you did the intake gasket, I know you have the skills to pull the valve cover.
Justinj360
Justinj360
Senior Member
Okay so are you saying the heads all crack in the exact same place? On a side note, could a blown head gasket cause a coolant leak?
Larryjb
There is a TSB out on this for 2001 - 2006 Tahoes (and others). The crack commonly appears around the oil drains, mostly on Castech heads. Mine is not Castech, but still had the crack in the same area. This may not be your problem, but it is easy to check. A blown head gasket could cause a loss of coolant.
Other areas that cause hard to find leaks:
water pump
thermostat housing
probably lots of others.
The best way to find these to get a coolant pressure tester and leave it on overnight and look for a puddle. When I wasn't finding a puddle, I sent in an oil sample and confirmed I had antifreeze in my coolant. Fortunately it was a slow leak so any water evaporated from the oil. However, the organic buffers used in the coolant stayed in the oil and began to sludge up my oil.
Justinj360
Justinj360
Senior Member
So today I finished putting it back together and ran it until it reached operating temperature then I changed the oil. When I first started the truck it made the same knocking sound as it did before. It was definitely coming from down low in the engine. Then after about 2 minutes of idling it all of a sudden stopped knocking and then sounded completely normal. I'm not sure what that was about but I ran it for probably 20 minutes total and the knocking never came back. My guess is that the oil wasn't soaking the bearings yet.
Also, while I was changing the intake gaskets I sprayed some Seafoam in the intake ports to help clean them up a bit. So when I started the engine I got the usual cloud of white smoke out the exhaust. Then I noticed that there was white smoke coming from somewhere down by the exhaust manifolds on both sides... This leads me to believe that I have blown head gaskets. Could that be true?
I took this picture looking up at the engine on the passenger side. You can see white smoke towards the front of the engine in the picture however in person you could see smoke along the entire length of the heads.
Do you have broken exhaust manifold bolts? Could be leaking from that, and once it warms up, the metal expands some so the smoke will stop.
Justinj360
Justinj360
Senior Member
Not that I know of. How would I check for that? It seemed to pour smoke out of both sides the whole time even after it reached operating temperature. When smoke stopped coming out the exhaust it also stopped coming from the engine.
Larryjb
Broken exhaust manifold bolts are so common, that's almost certainly what it is. Either that, or the bolts have worked loose. I had to tighten exhaust manifold bolts on my Buick 3.8L. I probably should have replaced the exhaust manifold gasket, but there is so much in the way on those FWD engines.
On the plus side, there is an easy fix from Kral Auto parts for the exhaust manifold bolts for the Chevy engines. They are "clamps" that clamp down on the exhaust manifold. However, before investing in this, forgive the broken record, but pop off your valve covers and take a look. I work really slowly on truck stuff. Many guys around here would have had both heads off in an afternoon, with time for beer. I've taken about 2-3 days. It only took me an hour to get the valve covers off to inspect. The head was already "clean" right around the crack, so it was very obvious.
This is what mind looked like:
https://www.tahoeyukonforum.com/threads/latest-oil-change-oil-filters.99646/page-4
SnowDrifter
Sasquatch Country
Smoke coming from the manifolds indicates a bad gasket, broken stud, or cracked manifold
You're doing to need to do some testing here one way or another. Pull the valve covers and rockers, put the cooling system under pressure. Watch for cracks seeping coolant around the pushrod tubes. If it's not that, then head gaskets are blown. If it is, then you need new heads
And not to sound like an ass, but you're going to need to do some investigating here soon before you default to rebuilding/replacing the engine. Get it done. Drop the pan, plastigauge and visually inspect bearings. Check oil pressure with a mechanical gauge. That'll give you a starting point to the minimum viable option for the repair.
Justinj360
Justinj360
Senior Member
You guys are right. I'll check the heads myself tonight. I'll pick up a coolant pressure tester after work.
PatDTN
Advance Auto or one of them will rent you a tester for free I think.
Justinj360
Justinj360
Senior Member
I was hoping I wouldn't find that logo when I took the passenger valve cover off... It also looks like I have cracks where everyone said they'd be. Do I even need to pressure test it? I didn't touch anything in there before I took the photos.
20180910_235110690_iOS.jpg 20180910_235202459_iOS.jpg 20180910_235218974_iOS.jpg
Larryjb
Are both left and right heads cracked? I feel for ya!
Justinj360
Justinj360
Senior Member
Have they revised the heads so they don't crack anymore in new engines?
SnowDrifter
Sasquatch Country
Little difficult for me to see in the pics cause my screen sucks
If you can see they're cracked, it's decision time. The way I see it, you have 3 options if you want to keep the vehicle
1. Replace the heads, change the oil a few times, hope for the best.
2. Go a little more in depth. While you have the heads off, inspect the rest of the engine. Look at the cylinder bores for scoring or glazing (crosshatches should still be visible). Drop the oil pan and check bearing tolerances and visually inspect their condition. From there, determine if a rebuild is needed, and if so, if that's something you want to take on
3. Say F-it and swap a junkyard engine in there
As far as your question about revisions, I don't know, sorry. Will need someone else to chime in
Justinj360
Justinj360
Senior Member
I am almost certain those are cracks in there. Would the oil make that pattern for any other reason?
Would it be worth buying a coolant pressure tester to confirm? There isn't a place here I can rent one from so I'd have to buy one and they're not as cheap as I'd like.
I'm leaning heavily towards option number 3 but that will depend on prices. About how many bones would an L59 crate engine set me back?
A lot of questions, sorry. That's not even close to the amount that's running through my mind right now though...
SnowDrifter
Sasquatch Country
If it wasn't pressurized, you'll need to do so. It's important to be certain before condemning an engine
Crate engine? 3 to 7k depending on a variety of factors.
Used one with 120-140k on out of a crashed rig from the local wrecking yard? ~1k. Call around some places local to you.
As far as what's the right choice? That's one you'll have to figure out. There a case to be made both ways, with the most appropriate one depending on nuance.
ScottS-Michigan
