I know I have posted this before in other threads and I am not trying to clutter your thread or start an argument but...
I have a 70% ceramic film over my entire windshield with a 8" 5% strip at the top.
70% is, essentially, a clear film which does very little for looks but the ceramic film blocks 99% of uvA and uvB rays which fade your interior and cause that brand new expensive dash to get brittle. It also blocks more than 50% of the heat.
And at 70% doesn't really interfere with night time driveabilty.
If you want to look at actual numbers then it goes like this...
Your stock windshield, if you checked it with a "tint meter" would register at around 70% VLT (visible light transmission).
You take the 70% windshield and add a 70% film and you are now at around 49% VLT.
If you use a 50% film on the same 70% windshield you are now at around 35% VLT. Which is what the legal limit is in most states for your front side windows.
If you don't drive much at night then it's really no big deal but if you do then it could potentially be an issue for you.
I just wanted to give you some real world data and numbers to chew on before you make your decision.
Here is a pic of mine... front windshield 70% film plus 5% strip and 18% on the front side windows to match the factory rear tint.
The Hüper Optik film is the ceramic film I went with. It is a German made film and is excellent.
https://huperoptikusa.com/automotive/
Hope this helps.
35% on my sides and shield, probably the 10th vehicle I have had it on, will do it again on the next.
Well la-di-da......35% on my sides and shield, probably the 10th vehicle I have had it on, will do it again on the next.
After a lot of adjusting of every part of the front end, I was finally able to get the bumper on and the headlights and grill lined up. There's a bit bigger of a gap between the bottom of the headlights and the bumper than before but I think it's probably a normal Chevy bumper gap now. View attachment 206420
In Nathan's bumper.Where are all the lights gonna go?
I took it back apart and added the brackets for the braces that mount further back on the frame, the fog light brackets and the fog lights, and mounted it up so I could finalize all the adjustments and tighten down the brackets and braces so now it mounts up to the truck easily and when I do, it’s all lined up. Now for paint and to see if that dent can be fixed or if I need a new bumper bar.View attachment 206495
I decided to quit messing around and ordered a Cerwin-Vega powered sub for under the driver seat. I don't want to spend $600 for the JL Stealthbox and then more for an amp and end up with a carpeted center seat that my dog would have messed up in no time, or mess with building something. I don't need super bass in this truck, just something better than what it has. The CV has the best reviews on Amazon for a powered sub that fits under my seat. For less than $200 I figure it's worth a shot. It is a 10" with 200 watts RMS and freq response of 30-150 hz which is better than most of them and it has an aluminum chassis and remote level control.
That’s fine. I figured as much since there’s no interior volume.Had it in my Acura, for about a week... None of those give decent low bass, only mid bass
