So, you blew a bunch of seals...
Ok so this is probably a waste of time, but every since I dropped my front license plate down, I haven’t liked the way it looks from the side. I like it from the front better, but from the side it looks like what it is. A license plate hanging on the bottom bracket. So today I mocked up a quick cover to see if I liked it better closed in. Here is the before and after of the peace I am using for test fit.
I like it enough better I think I will proceed with the project.
Out of stock? Not worth waiting for?
X2 on Moog but check amazon. I got both uppers for $90 for the pair. Moog lowers are also found on there for about $26 but I got one on a warehouse deal for $6.The front ball joints are not a bad job. The upper and lower ball joints, replace the entire upper and lower A arm. Get MOOG. The uppers are about 80 each on rockauto.com.
The radiator you should also be able to tackle your self.
How bad is the oil pan? If it's seeping, let it be.
Front hub for me was about 450 at the dealership.
Master cylinder you could prob do, but you can't bleed the system without being able to override the abs module, from my research.
Front axle seals- chevy quoted me $500. Mine were barley wet, so you may want to check what they mean by "shot".
Sent from my SM-N950U using Tapatalk
The entire arm, or just the ball joint?X2 on Moog but check amazon. I got both uppers for $90 for the pair. Moog lowers are also found on there for about $26 but I got one on a warehouse deal for $6.
Entire arm on the uppers. Bought amazon warehouse deal on both and got each for $45-50, so I guess it was $90-ish. The lowers were just the ball joint.The entire arm, or just the ball joint?
Hey, i know someone that needs the #’s off that wiring harness in console @Ron C
Hello all, I am in the midst of converting to all LED on the front of my Yukon, and I have a question about wiring. Has anyone here done a YUKON wiring in the load resistors? I'm not good with electrical testing, and I'm trying to figure out which 2 wires in my front blinkers to connect to. In the picture, you see that the blinker light has 3 incoming: 1 brown, 1 black, one green. And, it has 2 outgoing (2 the park lights), 1 brown 1 black. I want to say, via process of elimination (I don't think the park lights blink when the signal is on), that it is the black (ground) and the green (hot). But I don't know, and don't want to damage the wrong wire. Any help would be GREATLY appreciated!
Hello all, I am in the midst of converting to all LED on the front of my Yukon, and I have a question about wiring. Has anyone here done a YUKON wiring in the load resistors? I'm not good with electrical testing, and I'm trying to figure out which 2 wires in my front blinkers to connect to. In the picture, you see that the blinker light has 3 incoming: 1 brown, 1 black, one green. And, it has 2 outgoing (2 the park lights), 1 brown 1 black. I want to say, via process of elimination (I don't think the park lights blink when the signal is on), that it is the black (ground) and the green (hot). But I don't know, and don't want to damage the wrong wire. Any help would be GREATLY appreciated!View attachment 192732 View attachment 192733
my weekend project has arrived, I am upgrading my E fans to the HD cooling, picked up a used assembly off ebay for 199.00 with 200k on the clock and 2 new 700w motors from rock auto for $60&$40 so total cost $300, I don't trust those after market fans too many failure reports. dealer says the relays are the same so should be good to go......
