gpracer1
Phoenix
Installed LED tail lights and reverse light bulbs, opened up the passenger door pull (should be a recall / class action lawsuit as so many are broken due to weak design) and reinforced with small square steel rod and aluminum angle then poured in plastic epoxy.
kbuskill
NE. FL.
Got my preliminary custom tune installed on the Burb and put some miles on it so I can do another log to send to Lew.
Also got new plates today...
Really need to get on with color matching the bowties.
NGAneer
NWGA
well you could always buy one of those 8 point mic kits and place them all over under the truck and narrow it down that way, I have almost had to do that before.
I was almost there before taking the spray and pray approach with the silicone spray. Sprayed the LCA bushings, exhaust hangers, and strut isolators and mounts. After all that its gone and I can finally enjoy the new ball joints and the much improved ride.
On another note, a little disappointed that R1 was out of stock of the rear Geomet rotors, had to get eLines for the rear. Oh well, gotta be better than my warped rotors and unevenly worn pads.
HiHoeSilver
Away!
Chicago
Out of stock? Not worth waiting for?
randeez
south florida
Not sure if it's going to actually do much but came across the filter and shield pretty cheap to go with the airaid MIT .
dreww2001
STL
So the Tahoe came back from the shop yet again with another long list of things wrong with it, all 4 ball joints are bad, radiator is leaking, master cylinder is leaking, front left hub has play, front axle seals are shot, front and rear diff fluids are dirty (rear diff has less than 5k on it) and the oil pan is leaking and that's around a year old. Any suggestions or anyone else have these issues and know how much it might end up costing me or would it better to get rid of it. On a high school budget i cant afford to put thousands in repairs every other month, i love the car but just don't know if i can afford it anymore.
Chuck_Finley
Drew, sorry to hear but most of that stuff can be done yourself. I've been there with past cars and you never know when to cut your losses. How many miles on the truck?
scot moore
Ok so this is probably a waste of time, but every since I dropped my front license plate down, I haven’t liked the way it looks from the side. I like it from the front better, but from the side it looks like what it is. A license plate hanging on the bottom bracket. So today I mocked up a quick cover to see if I liked it better closed in. Here is the before and after of the peace I am using for test fit.
I like it enough better I think I will proceed with the project.
93blkongreenpro
The front ball joints are not a bad job. The upper and lower ball joints, replace the entire upper and lower A arm. Get MOOG. The uppers are about 80 each on rockauto.com.
The radiator you should also be able to tackle your self.
How bad is the oil pan? If it's seeping, let it be.
Front hub for me was about 450 at the dealership.
Master cylinder you could prob do, but you can't bleed the system without being able to override the abs module, from my research.
Front axle seals- chevy quoted me $500. Mine were barley wet, so you may want to check what they mean by "shot".
Sent from my SM-N950U using Tapatalk
you can get a decent moog front hub for around $125 on rockauto and what do you mean by front axle seals? they are cv boots which can be had for super cheap.
dreww2001
STL
Thanks! I got under it and there was fluid leaking all the way down the axle
dreww2001
STL
I’m not sure, the paper I got back said the axle seals and we haven’t gotten prices back yet
93blkongreenpro
The front diff seals
Korbin_A
