What vehicle related issue did you have today?
DirtyHoe2002
SE Nebraska
Wanted to start a thread to see if as many people have as much issues with their trucks as I do with mine.
Here is a place to vent about your issue(s) and who knows, maybe someone will be able to help.
I’ll start:
Today’s issue was that my dash lights stopped working on me out of the blue. One minute they’re working and the next thing I know they have no power. I checked every fuse and still nothing. Damn vehicle, can’t catch a break .
ScottyBoy
Shreveport, La
Hell, I am having an annoying squealing sound from my front brakes, sounds like it's more on the passenger side. But I just COMPLETELY redid all the damn brakes last year, so that's why I am kinda pissed off about it. Now I gotta go out there in the cold and Jack it up and take the wheel off just to look at it and see what the hell is causing the noise.
adventurenali92
Big Bear Lake, ca
I had to drop a pretty penny two weeks ago to have all the upper transmission lines that run to the cooler and back replaced because they were all leaking. That sucked.......
08grey
Found a leaky brake line.
Sent from my SM-G950U using Tapatalk
08grey
Hard. Right above the front shocks on the chassis. Going to drop it off now for repair. I'll update.
MINIz guy
I'm going through this right now. I'm really wishing I took my shop's offer of $550 for replacing all lines. It's taken me 10+ hours so far and I'm not done. I bet they would have just lifted the body a few inches and had it done with ease.
08grey
Good luck. I have no update on mine yet other than they still have it.
Idaho45guy
Idaho/Washington border
Kept getting an intermittent check engine light after I installed the new CAI and someone suggested disconnecting the battery to re-set the MAF. Un-hooked it for a few minutes, then hooked it back up and headed into town for a dinner date. Discovered that my HVAC controls no longer worked.
Hot air blew out from the vents no matter what I selected. When I pressed the AC button, I could hear the pump engage, but the air stayed hot. Just weird.
But the MAF adjusted and no more codes getting thrown...
Got back home and figured what the heck, I'll disconnect the battery and try again. Did that and now the heater/AC is back to normal and the MAF is good to go. LOL.
Idaho45guy
Now the check engine light is back on... I was spoiled by driving a 2014 Ram the past 4 years. Not a single issue. Trading this in on a new 4Runner as soon as all credit cards are paid off.
SmileB44Death
Seattle
Left parking lamp doesn’t flash for turns. And when I accelerate around 30 mph I hear this wine noise.
M1Gunner
Gainesville, Fl
Welp, my ac compressor pulley bearing gave up the good fight. Ended up replacing the clutch, coil, pulley and bearing with a -$100 rebuild kit. Didn’t have to evac/recharge, replace accumulator or any of that jazz. Now back to frigid winds lol I still call it a win in my book. The coils snap ring was a pain in the D I’ll have to admit.
2511B9D2-6524-46C2-BD59-F655A7218897.jpeg D33B723E-F1F8-4439-9AE4-68B47BA0F9AD.jpeg CA7A22CA-9395-499A-8D7E-BD7D3391A6D4.jpeg
M1Gunner
Gainesville, Fl
I’ll start:
So how’d ya fix it? Bad harness connection? The good ole solder fix?
DirtyHoe2002
DirtyHoe2002
SE Nebraska
Lol no, sounds stupid on my part. But my dimmer switch for the dash lights only works in some spots and I must of bumped it climbing in/out and thats why they weren't coming on. Tore my whole dash apart, all my fuses, everything, when all I had to do was turn the switch up a tad. Talk about feeling stupid. :signs75:
What's the matter with it?
I've always wanted to do that but could never find the parts. Where did you get just a clutch/rebuild kit? Part number?
M1Gunner
Gainesville, Fl
@swathdiver The only place I could find it was Autozone p# 47362 it’s normally 144ish but got a couple discounts thrown on it which dropped it to 105 and some change. I just really didn’t want to have to evac/recharge and replace the accumulator etc with replacing the whole compressor and breakin open the system when the compressor itself is still good.
The kit is available online as well but it was cheaper buying it in person which is bass aackwards lol I think online the kit was 160-170? At least what I came across.
Thanks Jason! I could not find and was always told that these didn't exist. Well, maybe they didn't twenty-five years ago when I was looking! We had a number of cars that just needed clutches back then and it was frustrating to go through all that work and expense when something much simpler was all that was needed.
M1Gunner
Gainesville, Fl
10.4 brother, it just makes sense to me. I don’t get why you can’t Get kits to service every compressor like this. It’s like “ah, crap! The counter weight on my harmonic balancer just broke loose and shifted. Guess I have to replace the whole engine.”
Candielaine
