What can the 3.0L engine/transmission take with regard to hard launching?
shadeandsound
I drive my 2024 GMC Yukon XL Denali super easy--I always start slow, accelerate smoothly, brake with pad/rotor heat in mind, and I don't ever, and will never tow anything. It's my most expensive vehicle currently and I put a lot of thought and patience into ordering it, so I want it to last a long, long time.
Well today, it looked like my precious, still-new-condition Denali was about to get rear-ended, so I launched a little hard to get out of the way--revved to about 3-4k I think, and surprisingly, even chirped the rear tires (it was in 2WD).
Now me, being a worrier, am worried about something prematurely going out in the transmission/torque converter, or having that 10-speed develop some kind of dumb bucking issue or something.
Is this something these big SUVs can actually take, since it is hopefully a one-off event?
Anyone here actually drive their 3.0L SUV fairly hard unlike me, usually, and have premature issues?
Stbentoak
Didn't hurt a thing. About the only thing this will do is you will see the fuel mileage plunge. I floor mine every time I get on I 75. Just to get it good and hot. It needs to be beat on a little bit. Diesel's don't like to be treated nicey nicey. They want to be worked.....
JayceeP
nothing wrong with being mindful of not slamming the gas or brakes arbitrarily but redlining it occasionally isn’t going to hurt it. I agree you should try and get the rpm’s up a bit every now and then too. But, it’s your rig, do it your way.
shadeandsound
shadeandsound
Thanks for that! Helpful to hear from you, as I know you have been in these SUVs a while--before buying, I read through a lot of your posts/replies.
I have always heard the same from my friends who have GM 6.6L and Ford 7.3L/6.7L/6.0L Diesel trucks, but I always wonder about this little 3.0L since it's my first diesel. I wouldn't question at all launching hard in my X5 or 911, but this thing is a hulk!
Marky Dissod
... today, it looked like my precious, still-new-condition Denali was about to get rear-ended, so I launched a little hard to get out of the way-
... me, being a worrier, am worried about something prematurely going out in the transmission/torque converter,
Is this something these big SUVs can actually take?
Making fun of you without intending to hurt your feelings. If you decide to be upset about it, report this post and ask them to delete it, hopefully they will.
OK
People like you are never as ******* your 'big hulking suv' as you think you are, except maybe by accident, once in a blue moon, etc.
You've no clue how the ecm mitigates the most sudden throttle kick from being reinterpreted into a much slower gradual throttle push - else you'd not be so concerned.
Should you make a habit out of testing your reaction time and 'cutting down the tree' quicker and harder than every other commuter every time? Of course not.
But since you already felt it necessary to ask, it's almost impossible for you to become a meph-addled leadfoot who'll be surprised at its durability in a few years.
Also, if the tires chirped, then it's highly likely that nothing inside the transmission did.
Impressive slingshot launches that hook with zero wheelspin are far more dangerous to any transmission, and the 10L80 is pretty durable.
Hopefully I'm wrong and you will not experience any of the issues that some people do from being dainty with a vehicle that was not built for dainty uses.
By the way, your brakes are also bigger and better than you think ... and, change your oil less often than every 6000 miles; that's about it.
shadeandsound
shadeandsound
OK
Well, the main reason I ask is that I don't consider this SUV to be remotely on the same level as a Silverado or Sierra with a 6.6L Duramax, in regard to being capable and designed for being used and abused, pulling incredibly heavy loads, etc.
To me they do seem more dainty--there is lots more rear body and interior weight, and overall less capability than the full-size trucks due to the smaller engine and lighter duty transmission.
So I was curious to know what anyone else with one thought. I like the exterior and dashboard in my pre-facelift 2024 much better than the 2025-newer (although I understand the LZ0 in the newer ones seems slightly superior to the LM2), so definitely trying to keep it many more years!
Marky Dissod
I'll go ahead and agree with you that it's a 1500, not a 2500 or 3500, but when you say you
'don't consider this SUV to be remotely on the same level', you're underestimating your vehicle, as if it were a 1/4 ton instead of a 1/2 ton, so to speak.
Feel free to stop treating it like a Rav4 or a CR-V. :p Knowing that you plan on never towing, do you happen to know what its tow rating IS (HINT HINT)?
Your engine, for the record is not as powerful as a 6.2L, but it is about as strong as a 6.2L SHOULD HAVE BEEN (certainly more reliable & durable),
and can surely work much harder than you plan to work it for YEARS.
Trying to assuage your concerns by giving you good reason to increase your confidence in your vehicle here.
P.S. : ******* = 'AR DONN
CTown Duramax
Like you, I baby my2021 LT Duramax and will never tow with it. Just once, though, I turned off my traction control and floored it. Wooooeee! Like my 6sp Z-28. I think i'll do it again. It fishtails.
I think you're pretty safe flooring it. Even w traction control off, the engine controls are still protecting the engine and tranny.
shadeandsound
shadeandsound
Glad to hear that! Since this happened, I've driven this one slightly harder than I had been whenever possible, and it is pretty impressive for the size and weight!
Marky Dissod
Turbodiesel engines are spec'd & built with chronic turbo reliance in mind.
Towing 11,000lb gently is easier on the engine than trying to get the best 60ft time every time the light turns green,
but even if you murder the cockroach with the throttle every time the light turns green, engine mgmt rolls the throttle open anyway.
Best advice I can give comes from a chauffeuse I know with a 2011 Lincoln Town Car with over 800,000 miles & counting:
baby it for the first 3-5min, & the last 3-5min. Don't push it hard til it's warmed up, give it a chance to cool down before shutting down.
kikeap
