Vortec 454/4L80e HD swapped 1999 Tahoe OBS
6.0 Carb Conversion or Stay EFI?
  • Carb Conversion
    Votes: 0 0.0%
  • Total voters
  • Poll closed .
bigfootchiro
bigfootchiro
Largo, FL
Sorry guys! Been MIA lately. Been crazy at the office!
Come to find out, I can’t use the LS injectors until I upgrade more of the valvetrain. So, when the 496+ stroker kit goes in will be the time to switch injectors. The stockers are plenty of fuel.
Also, I was looking for ways to bump up fuel pressure, like an adjustable FPR. Come to find out, I pulled FPRs off the shelf for a 454 and a 1997 350. They both use vacuum style FPRs with nipples (hehe, nipples); however, the nipple on the 350 FPR rolls down into a smaller outer diameter, but just slightly. The initial inlet of the same size, and the inlet hole is the same size. Height on the 350 FPR is just slightly smaller, but just the outer portion, not the portion that sits in the fuel rail. If this works, this will bump pressure up from 50 PSI to 65 PSI, and it’s cheaper!!!
New upgraded 4 hole Bosch injectors and FPR going in this weekend!
Also, 0411PCM on its way! It’s been tuned, road tested, and I have all the instructions and pinout diagrams to do the swap!!!
bigfootchiro
bigfootchiro
Largo, FL
Look what came guys!!! Finally, the long spoken about 0411 PCM. Custom tuned for the 454 by James, the owner of PCMPOWERTUNES. I’m so excited to get this installed! Rear O2s deleted, tuned for the tires and gears, transmission has a “moderate” tune (next step was aggressive), VATS is deleted, Tow/Haul mode is active (he gave me instructions on how to use it), and I’m sure I’m missing things.
OH! New injectors in, 65 PSI FPR (vs stock 50 PSI), spark plugs, and the front brake pads were replaced due to them being bad from the factory.
RST Dana
EMT/First Responder Firefighter Supporting Member
OH
Five O was hiding at the intersection?
26AT4
