solli5pack
- Joined
- Jun 17, 2023
- Posts
- 500
- Reaction score
- 772
I replaced the stock bolt with an ARP...
Will 2008 have vvt solenoid and actuator on the timing cover?Yes. Balancer and water pump removed, you can then remove the front cover. ("While you are in there" comes up of course. Oil pump, timing chain set, tensioner. Camshaft sensor. VVT solenoid and actuator for VVT engines)
Stock on the Denali and 51 PU, ARP on the vette, and no VVT.I replaced the stock bolt with an ARP...
So my 08 Yukon SLT has AFM turned off from GM? I know it has the components because I've seen them when the head was off. Currently using a Range plug in to keep it from activating. I'm pretty sure I saw it cycling from V4 to V8 on the DIC but gotta verify.Won't have VVT until 2010 model year, but some 2008 5.3's had the AFM components.
I was absolutely terrified when re-installing the balancer that I was going to strip out the crankshaft. First and only one I've done so far.Stock on the Denali and 51 PU, ARP on the vette, and no VVT.
Hopefully you're not turning a bolt to install it ...you need the threaded stud, with turning the nut. Grease on a thrust washer, or use the bearing that came with it. Usually go on without a problem.I was absolutely terrified when re-installing the balancer that I was going to strip out the crankshaft. First and only one I've done so far.
It depends if the front crankshaft seal has worn a groove in it. It's sort of a judgment call. If you can't feel the groove with your fingernail, I have polished them up with 2000 grit while turning on a metal lathe at high speed. But if it's got over 150,000 miles on it.... I usually just pick up a replacement before I get started. (And some of those have looked pretty good.) New ones are around $100can the harmonic balancer be re-used??? also anyone have part number for arp bolt?
I’ve had good luck with the ARP website for part numbers. It’s well organized by vehicle and application. Their tech support line is also great if you want to confirm details.can the harmonic balancer be re-used??? also anyone have part number for arp bolt?
That’s the one I used, worked great.
Man he must have really yanked on the tail end of that trans in order to get that much leverage and force to break the housing. Idiot. A guy can tell when what he’s doing is wrong if he just pays attention to that little man in his head that says “ I know I should stop but…”Make sure you get all the bell housing bolts..my "helper" missed one and swore it was just "stuck".
It was me wiggling the engine, and twice I stopped and asked him if he was sure he got all the bolts. Oh yeah, for sure...Man he must have really yanked on the tail end of that trans in order to get that much leverage and force to break the housing. Idiot. A guy can tell when what he’s doing is wrong if he just pays attention to that little man in his head that says “ I know I should stop but…”
Outta all the bell housing bolts, I think that one is the hardest one to get to.Make sure you get all the bell housing bolts..my "helper" missed one and swore it was just "stuck".
