Torque Converter Bolt help
blondie70
I got that cam in my Tahoe. Wish I would have gotten a higher stall torque converter becuz the truck will lunge at times at idle....I like the way it runs, however....I generally just put it in neutral at a stoplight.....
L
lspann3525
Yes. Balancer and water pump removed, you can then remove the front cover. ("While you are in there" comes up of course. Oil pump, timing chain set, tensioner. Camshaft sensor. VVT solenoid and actuator for VVT engines)
Will 2008 have vvt solenoid and actuator on the timing cover?
rdezs
Won't have VVT until 2010 model year, but some 2008 5.3's had the AFM components.
solli5pack
So my 08 Yukon SLT has AFM turned off from GM? I know it has the components because I've seen them when the head was off. Currently using a Range plug in to keep it from activating. I'm pretty sure I saw it cycling from V4 to V8 on the DIC but gotta verify.
solli5pack
Stock on the Denali and 51 PU, ARP on the vette, and no VVT.
I was absolutely terrified when re-installing the balancer that I was going to strip out the crankshaft. First and only one I've done so far.
rdezs
Hopefully you're not turning a bolt to install it ...you need the threaded stud, with turning the nut. Grease on a thrust washer, or use the bearing that came with it. Usually go on without a problem.
j91z28d1
he was probably taking about tightening the oem bolt. it's kinda crazy how tight that bolt should be.
it's easily twice as tight as the arp nut. with sealer on the threads. and a under bolt bolt head sealer/friction surface.
rdezs
Lol ... I have a 48 inch, 3/4 drive breaker bar for the final angle torque. Absolutely terrifying that it's going to snap. I swore next time I'll just get the ARP bolt and torque it down the old fashioned way.
L
lspann3525
can the harmonic balancer be re-used??? also anyone have part number for arp bolt?
rdezs
It depends if the front crankshaft seal has worn a groove in it. It's sort of a judgment call. If you can't feel the groove with your fingernail, I have polished them up with 2000 grit while turning on a metal lathe at high speed. But if it's got over 150,000 miles on it.... I usually just pick up a replacement before I get started. (And some of those have looked pretty good.) New ones are around $100
Dirty looks
Make sure you get all the bell housing bolts..my "helper" missed one and swore it was just "stuck".
Man he must have really yanked on the tail end of that trans in order to get that much leverage and force to break the housing. Idiot. A guy can tell when what he’s doing is wrong if he just pays attention to that little man in his head that says “ I know I should stop but…”
Dirty looks
It was me wiggling the engine, and twice I stopped and asked him if he was sure he got all the bolts. Oh yeah, for sure...
Third time was the charm.
Charlie21ny
