Most of the time these hvac actuators end up having broken one or more of the old brittle plastic gears inside.have an issue with the mode door actuator on our Envoy
Do these work on the newer 15'+ models?
One word of caution. Within the past 6 or maybe 8 months I have read in another website of these being confiscated by US Customs.
https://gmtnation.com/forums/thread...-gm-tech-2-scan-tool.17878/page-6#post-578969
There should be like a telephone type cable and 9-pin serial adapter that came with it. The cable plugs into the adapter and becomes a 9-pin serial plug. Most newer PCs don't have the 9-pin serial port so you have to get a USB to Serial adapter.
Oh, I thought you were asking how to hook the Tech2 up to the laptop to download updates and stuff or review live data logssorry, I don’t understand what you mean.
I don’t have a tech2. I want to use a laptop and software instead of a tech2.
Cool!the vxdiag comes with techII win and gds II software, it's a little tricky to get the software installed and working but once you have it setup it works fine just like a techII, I have both and a mdi
if you get the vxdiag when you go to install the software turn off any virus or security software and disable windows security functions or it will just flag or delete files during the install and it will be a pain in the dickCool!
I found a pretty good write up on installing the software. They didn’t sat anything about the security software but I imagine it applies.if you get the vxdiag when you go to install the software turn off any virus or security software and disable windows security functions or it will just flag or delete files during the install and it will be a pain in the dick
well the best option seems to be a hard drive that has the software pre-installed, they run about $100 the only catch is you have to put it in a lenovo laptop, like a t22 or t23 something like that it says on the website which laptops it will work in, a used lenovo of that model runs about $100-150 (on ebay) depending on the condition, cheaper if you just buy one without a hard drive. another catch is you still have to have the usb adapter, but the software installed on the hard drive seems to be a good bang for the buck.I found a pretty good write up on installing the software. They didn’t sat anything about the security software but I imagine it applies.
Did you research for any other cables or is this about the best option?
