SOLVED: TPMS won't stay learned?
KidWgn
Certified Kid Hauler
St. Louis, MO
2012 Tahoe LTZ
New Schrader 33560 TPMS sensors
All remotes work perfectly and do not lose sync, so I don't think it's a problem with the RDL module.
I can succesfully program the TPMS sensors, and view pressures on the DIC.
As soon as I turn the truck off and back on, I get "--" on each tire again.
I'm losing my marbles here. Are the sensors faulty? Were they programmed incorrectly?
EDIT/SOLUTION: Turns out the RCDLR had somehow lost its memory. I used my bi-directional Launch scanner to rewrite the tire type as P-metric, and the suggested pressure as 36psi, and everything works fine now.
bill1013
Air Force EMT/First Responder Firefighter
Waianae, Hawaii
What relearn tool are you using and are you following the instructions? This relearn tool is what I use. I got it on Amazon for $13. Good luck!
KidWgn
KidWgn
St. Louis, MO
That very same tool, actually! It learns the sensors fine; once I shut the truck off, it forgets them.
Put a scan tool on the truck and look for any BCM or Chassis codes. Any other vehicles nearby with TPM sensors?
That's tonight's project. My scanner was dead and needed updates yesterday.
The sensors are Schrader's multi-frequency sensors, and I'm wondering if they didn't program them correctly. If that's the case, though, wouldn't they not display AT ALL?
I hate stupid mysteries like this. I wish I had a known good set of TPMS sensors to test on the truck.
This is why I do my best to stay away from aftermarket parts.
Schrader is the OEM for the tire sensors.
Schrader is an OEM supplier but those are not OEM sensors. Big difference.
For example, Delphi is an OE supplier for oxygen sensors. However, the Delphi sensor and GM sensor made by Delphi are different and often don't work the same as they are different. They look different and the computer sees the information they provide differently, often being unable to accurately calculate the alcohol content of the fuel.
KidWgn
KidWgn
St. Louis, MO
That's fair.
The Schrader valves I used are their "new and improved!"
Now I'm wishing I had just bought the OEM 21507 sensors.
And of course, I bought the sensors like a year ago, and just now got around to installing them, so I can't even return the $100 worth of sensors. Oh well.
GMT800 2005 Tahoe Z71
Navy Supporting Member
The multi-frequency sensor is called a T10 sensor, if that info helps at all. Operates between 315 mhz to 455 mhz....I think.
That's fair.
I bought GM OE sensors from this guy in November last year. $48.25 delivered for all 4. Work as they should.
Moderator
People's Republic of Colorado
Not "between," it's either or, depending on the vehicle requirements. Frequency is programmed when the sensors are initially activated by a programming tool (not to be confused with an inexpensive tool used to re-learn wheel positions).
EDIT: I wonder if the sensors were programmed ("initialized" is what I'd call it) for the truck, or they're not pre-programmed.
You'll probably need a good tool that will read their IDs and write them to the truck. I have an Autel scanner that can do the initial programming of Autel MX-sensor sensors, as well as write them to the truck through the OBD port.
bill1013
Waianae, Hawaii
2012 Tahoe LTZ
It’s important to get TPMS that are made or are compatible to your vehicle’s computer system. Also, not installing them right away or waiting a year might be a problem. Hope you get it figured out.
KidWgn
KidWgn
St. Louis, MO
SOLVED!
Somehow the RCDLR had been..."cleared"?
I used my handy-dandy Launch bi-directional scanner to pull it up, and lo-and-behold, the tire information was blank. Rewrote it as P-Metric with a "suggested pressure" of 36 psi (correct load rating on a 285/45-22) and everything is working now!
KidWgn
KidWgn
St. Louis, MO
That's what I was afraid of, is that they were not initialized as 315mhz when they were installed. I wouldn't think that they would temporarily read correctly if that were the case, though, which is why I was so stumped on this one.
KidWgn
KidWgn
St. Louis, MO
Thank you for posting your solution to your issue. Our collective knowledge base has been increased.
That's why I still use forums in 2025, lol. You can actually search for things.
Not to mention, facebook groups are chock full of the same question about oil pressure 300 times a week.
BadDaddy2003
