the idle is unstable now if you tap on the gas the engine will have 3 addional echo engine revs...
so say if you revv the engine to 800 rpm it will go down to 590 then revv back to 800 then back to 590 then to 800rpm then settle at 590-620rpm......i would really like to fix this "issue"... i have a trip pretty soon this month
honestly i think the engine is toast it sounds horrible on #3 and #5 cylinder(slightly worse then #3) #1 and #7 cylinder sound fine..
i'm going to clean up the ground wires and a adjustment to the map sensor as well as check the air filter maybe it sucked up some snow ?
