So the P0069 is back again with new "symptom" echo engine revving.
BG1988
the idle is unstable now if you tap on the gas the engine will have 3 addional echo engine revs...
so say if you revv the engine to 800 rpm it will go down to 590 then revv back to 800 then back to 590 then to 800rpm then settle at 590-620rpm......i would really like to fix this "issue"... i have a trip pretty soon this month
honestly i think the engine is toast :( it sounds horrible on #3 and #5 cylinder(slightly worse then #3) #1 and #7 cylinder sound fine..
i'm going to clean up the ground wires and a adjustment to the map sensor as well as check the air filter maybe it sucked up some snow ?
B
BG1988
loose air intake clamp the one that connected to the throttle body was loose waiting for it to learn the new idle typical GM i swapped back to the old MAP sensor as well
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
Why do people still post with no vehicle info? Am I just expecting too much?
wjburken
Eastern Iowa
Brent’s saga with his Hybrid Tahoe is scattered over a dozen or so threads.
Take a peak at some of them some time and read. It’s rather interesting.
OR VietVet
Willamette Valley
I look forward to searching for info to try and help without, 1. Not knowing about what you just said about info all over and 2. Having to search when the info could easily be in a signature or supplied with the post so I don't have to go looking for that info.
So, in a nutshell, I did get the answer to my second question, I am expecting too much. I will file that away in the "who cares" department. LOL!
wjburken
Eastern Iowa
@BG1988 , Brent, can you please give @PNW VietVet a brief run down on how you got to this particular point with your Tahoe? He is not familiar with its history.
OR VietVet
Willamette Valley
I don't need the whole history unless the current problem needs that history for it to make sense. I was only asking for year and engine size. I thought that was pretty easy.
:2cents:
HiHoeSilver
Away!
Chicago
:2cents:
Pretty sure @wjburken's request was as much for us as it was for you...;)
Fasten your safety belt, and keep your arms inside the tram.
B
BG1988
The problem was Un-metered air was entering the intake just before the throttle body.. . only time will tell though I reinstalled the old MAP sensor. but have the new one on hand...
the one turn loose on the alligator clamp.....
idles very smooth now..
it doesn't have that rhythmic vibration idle jerk like before
valve are still clacking but that is another story
it's pretty sloppy for a shop to tamper with someones car just to drum up business.... esp not tightening the oil filter correctly
B
BG1988
tahoe hybrid 6.0L v8
basically after getting an oil change at the chain shit shop i got a Check Engine light.. the very next day
The Suv Stalled out a few feet from the train tracks as I was about to cross (still had the right of way as the arms were not down yet and the train was a couple of miles away)
mind you this was a heavy rail passenger train coming towards me at 50-60mph..
I was able to get it restarted that is when the CEL came on
So
i bought a Code Reader it came up with P0069
when I got home to find out where the location of the sensor was
I opened up the hood and lifted up the "plastic beauty cover" that magically was covered with fresh dirty motor oil...:rolleyes:
to find the sensor was unplugged..
ironically the only people to be touching dirty motor oil was the shop the previous day
basically I had been chasing this since then ... since the last 7k or so miles...
on the next oil change they figured that did not work... so they upped the antie and did not tighten the oil filter correctly hand tightened as they claimed... it's physically impossible to tighten it enough to manufacture specification by hand for the plug or filter (seeing as there is no clearance for ones hands to do so)..
basically it ran for a while on very low oil causing damage to Bank #1(since it rarely see v8 mode) this uses the VVT system unlike the push rods, VVT system is more sensitive to oil loss another guy all ready permanently damaged his engine... (it was a Gen V engine but had the vvt system when it ran low) mind you it was 4 of 8 qt in the system "when it caused damage"
mine got to about 2-1/2qt with in 164 miles from 6qt
oil was overheated and cooked and smoke poured out of the filler tube 0 oil shown on the dip stick
they tried claiming it would have sprayed oil everywhere ..... even 30 drips per min = almost 1 liter per hour...
at some point I decided to clean up the inside to discover the air bag modules have been tampered with... on both the passenger and driver side.. that mostly likely means they popped and replaced with questionable parts(we can bet it was a unlicensed body shop) since it was not logged on carfax or reported to the state DMV and there was a nice hole drilled into the passenger door :eek: that means some body work was done... I am currently presuming a claim with the dealers bond for this undisclosed moderate accident also something seems off with the rear passenger side door...
as the value was way less then I was charged for the suv at the time.. I pretty sure they knew about the damage... even if they did not know the state law is still on my side.. they also claimed the vehicle was "safe" it had NON-WORKING rear brakes.... when they sold it to me.. I could not figure out why I was stopped in the middle of the street but they locked up (all 4 wheels)and started working sorta then only to find out there was NO pad left on the brakes :Boo:
:blah:
I did replace the sensor that worked for a while then it was back
then i replaced the battery(needed replacement anyway) that worked for a while then it came back recently
then it was back again
wjburken
Eastern Iowa
So
:blah:
Thank you for the recap. That should get Ron up to speed.
HiHoeSilver
Away!
Chicago
So
:blah:
Since it may be relevant to this particular thread, what about the whole MAP sensor engine runaway thing?
Come on Brent, that’s a small part of the story. I think it’s time fir a COMPLETE RECAP of everything up to this point. And if you’re so inclined, add some colors and bold letters, random pictures, etc. I’m serious, we don’t mind. I actually look forward to your posts, and the story since the day you bought it is really quite interesting reading.
B
BG1988
yes that
but it still does not make sense that it was by-passing the electronic RPM Governor
also I did clean the ground wires it improved the voltage in the system by 0.1 volt to 14.7 volts as reported by the BCM data stream
it was reporting 14.5-14.6 volts before
BlacktopBandit76
