George B
¯\_(ツ)_/¯
Just looking for options. I would not be happy with the crappy design they used either. The fill tee looks simple enough too.
I don’t know, I might try. It’s on an ear of the tank. It’s leaking on the inside of this hole. The problem is if I make it worse and it won’t hold coolant in the system I probably shouldn’t drive the truck.View attachment 247653
Yes flat head Allen head screws and yes the ear must be hollow, there’s a seam that runs right through both mount holes horizontally instead of that part being solid plastic like you would think it would be. Like I said, it’s a shit design. That plastic seems to squish down when I tighten the screw down. Probably why the epoxy i flowed in from inside the tank didn’t fix it.Looking back I see that now. Must be flat head screws. Is that ear hollow?
I actually thought about doing that but was thinking that might open up a can of worms but you might be right, now that someone else thought of it maybe it’s not so crazy after all. I might give it a try, hopefully I don’t mess up the tank worse than it is.First I was thinking you could go at it with a tiny drill bit at a shallow angle to "route" out a slot along the leaking seam, then pack it with epoxy. Now I'm thinking you could use a thin cut-off disc to slice the seam on the whole ear, spread it apart with a screwdriver or wide pry tool, fill the entire ear full of epoxy and clamp it back closed to cure.
X2Thats ******!
After using that JB Weld Plastic Epoxy to repair a few mounting tabs for some rather large headlight assemblies, I'd trust it or anything similar. Having the whole ear filled to keep it from squashing should be a permanent fix. I'm thinking you'd fill one half and let it sit until the epoxy sets up enough to stay in place when inverted, then flip it to fill in the other half as quickly as possible, remove your spreader tool so the two filled halves connect, then lightly clamp and let cure.
Yeah but are you trying to save me money or cost me money because those options are all over $125....some are waaaaaay over lol.
Yeah, I thought I was bad until I started watching you. Now I feel better.Let me know if you need anymore help spending money, I'm pretty good at it
I'm with you Mark. I bet you could have something better fabbed up.The ******** at Whipple emailed me back to say it’s out of warranty (duh, I told them it was) and the $125 is actually a discount, retail is really $175. Which is a bunch of shit since there is no part number and they’re only included with a supercharger bundle unless your original pos tank develops a leak. And even if there is a part number, Whipple is the one setting the price. F them. I’ll spend more money for a nice aluminum tank before I pay them a dime.
No, I’m not interested in doing that even if it’s possible. I’m pretty sure it runs way cooler than the engine cooling system. 5-8 psi.you can't integrate it into the vehicle cooling system? how much pressure does it hold?
There’s no room for a 2.4 gallon tank.this is what i was thinking after he showed the "fill T", nix that and get a cheap ice tank thatll mount in that corner if all you need is a fill/bleed point
https://www.amazon.com/Tank-Reservoir-SuperCharger-Water-Intercooler/dp/B00EPYNQAI
