Rims problems 305/40/R22 HELP !!!!!
NappyBoy
Kuwait City
Hi TahoeYukon Forum im new here :Big Laugh: so im not sure if im posting in the correct section so let me make it quick
i installed in my 2011 tahoe 22 inch rims with tires of 305/40/R22
now the problem is i want to install 2/3 drop kit from G-Force but the problem is i have a heavy weight family when i take them all each time i turn i get rubbing with the stock suspensions any help? should i change tires or do something help ! :hmmm2:
ps. i dont wanna sell my rims
ps. my first language is arabic so im sorry
NappyBoy
NappyBoy
Kuwait City
Hi TahoeYukon Forum im new here so im not sure if im posting in the correct section so let me make it quick
godoy
utah
Where are you getting the rubbing
Front?
Sent from my TeleFonO!!
Goodinblack
I Like Tacos
Dirty South
You need Helper bags in the back.
You are having this problem on the stock suspension?
If you drop it, the problem will be worse.
You need to measure the distance (inside the spring) between the top perch and the bottom perch.
I run Airlift 60742 with drop springs.
22's should not rub though....:think:
NappyBoy
NappyBoy
Kuwait City
I really dont know but can you enlighten me cuz even the front when i go on a ramp
Modded
That Guy
Helper bags should not be your first resort.
Install the drop kti first, then trim the areas of the fender liners (plastic in the wheel area) that it is rubbing on.
I have a 3/5 drop on 26" rims and do not have helper bags, so I doubt you will need them.
NappyBoy
NappyBoy
Kuwait City
Even if i carry 6 people in the car wont rub if i do that ?
Modded
That Guy
Depends on how heavy those 6 people are.
Yesterday I had me, my 185 lb brother, 205 lb brother, 185 lb friend, and 60 lb little brother in the car and I only rub on big dips.
---------- Post added at 02:32 PM ---------- Previous post was at 02:28 PM ----------
I also forgot to mention my 200 lb stereo system.
I don't have a spare tire or third row though.
NappyBoy
NappyBoy
Kuwait City
I have a third row seats plus mine rubs when i go on a ramp from front
mordy913
