Questions for those with the resonator delete...
Decrow
SOCAL
Here are pics of the resonator removal, before and after.
soulsea
Administrator
Bar
Nicely done Jason.
How do you like the little extra rumble? :)
G
Green Machine
Orange County, CA
I'm hoping to do a similar test soon. Just need to find the time.
Jason, did you cut away some of the resonator piping that goes around that "fat pin" near the exhaust clamp? I could swear on my truck, the pin goes through a hole in the pipe that would keep me from slipping the resonator off.
Decrow
SOCAL
I like it a lot better then how quiet stock was. I still would like like to add a Magnaflow or Flowmaster muffler (any recommendations). I must thank you, for you and this thread were my inspiration. I went to the local muffler shop to have a custom cat back made, but the owner was apprehensive because he never saw or worked on a Hybrid, he wasn't sure how it would effect the vehicle.
So, Thank you to all the Hybrid owners on this forum, I have found a new home!
Green Machine,
I did not have to do any cutting to remove the resonator, loosen the 15mm nut disconnect the bushing from the driver side and twist/wiggle it free from the clamp. I did have to cut to put my exhaust tip on.
Pretty simple operation with minimal mechanical ability.
G
Green Machine
Orange County, CA
I FINALLY got around to pulling off the resonator. There is only a little bit more rumble at idle. Can hear it a little while cruising, too. No droning. Haven't tried wide open throttle yet. The wife didn't notice until I told her so that's a good thing!
jtidd
