02Lightning
- Joined
- Jun 8, 2009
- Posts
- 488
- Reaction score
- 105
Where do I start? I put NTK front o2 sensors in about a month ago. No problems with the old, just maintenance.
I have the Torque Pro app, I didn't think think vehicle had a flex fuel sensor?Check your ethanol percentage with a Tech 2 or an OBD2 adapter and Torque Pro app.
No other symptoms.Does the engine idle rough or have any other symptoms (like hard starting) or just the code?
Not sure of that, I'll have to look and see how to do that on Torque Pro if I even can.And what do your long term and short term fuel trims look like, at idle and at 2000 rpm? Both banks...
I thought NTK made the sensors for GM? I did valve cover gaskets about a month ago, along with cleaning the MAF, throttle body and replacing the front 02 sensors, I will go thru and recheck my work. I did just find out I have an oil leak, from intake valley tray, so I'm hoping maybe it's caused a vacuum leak? I have parts ordered and on the way for this. I would have thought an engine light would have showed up after a month with new O2 sensors.Replace the oxygen sensors with OEM ones only. Make sure the air filter is good quality (OEM also recommended) or if it is a K&N or similar with oil make sure the oil hasn't coated the MAF. Make sure all the intake duct clamps are tight and the duct isn't rolled. Make sure all the PCV tubes are connected and not broken. Make sure the oil cap and dipstick seals are good. No exhaust leaks. If none of those issues are present and the code still returns with the OEM oxygen sensors (pre cat) then you will likely need injectors (and do NOT buy the cheapo knockoffs on eBay and Rock Auto).
NTK is the same company that makes NGK spark plugs. Damn, wouldn't think that would break that easy. Just a clip holding them right?I’ve never heard of NTK. Usually Bosch or Denso makes stuff for GM but just because it’s made by them doesn’t mean it’s the exact same part. Yes, in theory if it’s the injectors it would change banks if you swapped them but I wouldn’t recommend that. You have a high probability of breaking them getting them out of the rail and you will need to buy a seal kit if they don’t break. I just replaced the injectors in my Yukon just because it has 187k miles on it and half of them broke and it’s a 12.
