Oil Pressure
jakcol997
Hey guys! Looking for suggestions, my
Oil pressure when I start my car is fine. As soon as I start driving, and it gets up to temp, every time I stop at a light or anything, it bottoms out to zero and my check gauges light comes on. I just replaced my oil pressure sensor. And that didn’t seem to fix it. Any other suggestions as to what it could be?!?!
Mechanic421
06 Denali XL
Statesville North Carolina
Any mechanical oil/transmission pressure gage need a adapter like the end of oil pressure sender. Harbor freight if in a pinch or maybe mail order if you have time to wait.
drakon543
when you changed the oil pressure sensor did you make sure the port was clear. if there was build up inside the port. too much buildup inside small port for sensors like the oil pressure sensor can give you odd readings. quickly dropping rpms as in a stop will cut the pressure/flow down obviously but for a brief moment the sensor could read 0. the build up will act like an orifice and choke it down and at the moment the pressure drops the pressure built up at the sensor will release back through the buildup dropping your reading. until the pressure builds back up on the sensor side of the buildup it wont read enough and can trip your light. also x2 on the test it immediately with a mechanical gauge poor oil pressure is a quick road to serious repairs if its not addressed.
iCajun
How many miles on it? Did it just recently start doing this?
jakcol997
jakcol997
It has 247K on it, it’s been acting up for a while. And I just got an oil change at the beginning of the month. That thing was such a C#%T to replace if I seriously have to do it again, I’m going to scream, there is NO room in between the firewall and the damn thing
Mechanic421
06 Denali XL
So old school R code 5.7 . With 250000 best case hopefully just a gage issue,but I am sure you know 250 and 21years old. First is test. There could be a number of things going on. I would pull a little oil out and look at it in the sunlight for metal flakes. If on flakes hopefully maybe a oilpump will help. Otherwise time to pull and tear down.
iCajun
It sounds like valid readings. Likely the engine bearings and oil pump are worn. The positive side is engines don't require much oil pressure at idle. A 20w-50 oil may help.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Having an accurate pressure reading will help alot. put a gauge on it. i have seen them idle at 5-10 PSI and live for a long, long time. 10w-30 or 20w-50 may help. 10W-30 works ok in cold climates too. You really need to know what the pressure is at idle.
jakcol997
jakcol997
Okay! The hard part is working on it, cause my apartment complex you can’t work on your vehicles! (Plus I work where I live, so I HAVE to set a good example.. lame) I’ll get a gauge and give it a test! Would an oil flush help maybe?? I’m trying my hardest NOT to tear anything up, considering I’m a 22 year old with very little to none mechanical experience..
George B
¯\_(ツ)_/¯
I wouldn’t flush it. With that many miles you are asking for trouble.
Did this start before or after your oil change?
mfinta
