Oil Pressure
jakcol997
Hey guys! Looking for suggestions, my
Oil pressure when I start my car is fine. As soon as I start driving, and it gets up to temp, every time I stop at a light or anything, it bottoms out to zero and my check gauges light comes on. I just replaced my oil pressure sensor. And that didn’t seem to fix it. Any other suggestions as to what it could be?!?!
Mechanic421
06 Denali XL
Statesville North Carolina
Any mechanical oil/transmission pressure gage need a adapter like the end of oil pressure sender. Harbor freight if in a pinch or maybe mail order if you have time to wait.
drakon543
when you changed the oil pressure sensor did you make sure the port was clear. if there was build up inside the port. too much buildup inside small port for sensors like the oil pressure sensor can give you odd readings. quickly dropping rpms as in a stop will cut the pressure/flow down obviously but for a brief moment the sensor could read 0. the build up will act like an orifice and choke it down and at the moment the pressure drops the pressure built up at the sensor will release back through the buildup dropping your reading. until the pressure builds back up on the sensor side of the buildup it wont read enough and can trip your light. also x2 on the test it immediately with a mechanical gauge poor oil pressure is a quick road to serious repairs if its not addressed.
iCajun
How many miles on it? Did it just recently start doing this?
jakcol997
jakcol997
It has 247K on it, it’s been acting up for a while. And I just got an oil change at the beginning of the month. That thing was such a C#%T to replace if I seriously have to do it again, I’m going to scream, there is NO room in between the firewall and the damn thing
DrSpork
